Thread: help
Results 1 to 6 of 6
  1. #1 help
    Apr 2015
    west virginia
    Do I need to take a paint pen and make a mark on my flexplate and torque when I separate the engine from the transmission. So they can be lined back up when I put it back in????
  2. #2 Re: help
    Donating Users timboku's Avatar
    Montgomery, IL
    No..only 3 bolts, once you get one in, the other 2 will be lined up.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: help
    There are no balance reference points to worry about. Pull apart and smile.
  4. #4 Re: help
    Apr 2015
    west virginia
    What I mean is does the flexplate and torque convertor have to be lined up exactly in the same spot they were when I separate them not the bolt hole the position of the two...I had to on an all wheel drive didn't know if front wheel drive was the same
  5. #5 Re: help
    Apr 2015
    west virginia
    Good deal thanks billboost37
  6. #6 Re: help
    NP, however since you seem to work on more than just a simple GM car.. when in doubt, you can't go wrong by marking it.
