Thread: Cooling issue
Results 1 to 12 of 12
  1. #1 Re: Cooling issue
    St. Louis
    Quote Originally Posted by ZSharp1985 View Post
    Yes I was told I might need to bleed it, I wi try that...any tips for the process?
    Per Scotty- open the rad cap, let the car idle till the fans come on, then open the bleeder screw till a solid stream of coolant comes out. then shut the screw, top off the rad,and cap it.
  2. #2 Re: Cooling issue
    Apr 2015
    Canada
    Quote Originally Posted by FordMan77 View Post
    What do if coolant steadily leaks out of the rad while car is running? Even if I take the rad cap off when it's totally cold then start the car fluid starts coming out of the opening.
  1. cooling fan issue or not?
    By idrivejunk in forum General Tech Discussion
    Last Post: 06-29-2014, 04:57 PM
  2. cooling issue
    By stlunatics2oo3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2013, 01:54 PM
  3. Cooling issue with 00 gtp
    By 3CLiPSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 04:02 PM
  4. Cooling issue
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2011, 06:43 PM
  5. Cooling Issue
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 06:51 AM
