Thread: Help with Harmonic Balancer - I took it off and can't get it back on right.
Results 1 to 20 of 23
  1. #1 Re: Help with Harmonic Balancer - I took it off and can't get it back on right.
    looking through one of the threads linked here i found this pic. i think your taking the timing cover off and the cam gear then you'll get it right out.
  2. #2 Re: Help with Harmonic Balancer - I took it off and can't get it back on right.
    SE Level Member Wraith888's Avatar
    Twin Cities
    I was able to get this fixed. It turns out when I gunned it on without sliding it to fit the key, I had the HB spun 180 degress from what it should of. The key pushed against the metal on the inside of the HB and that created a bump that wouldn't let me slide the HB on properly. I was able to carefully file it down just a little bit and it slide on and now everything is good.
    Thanks everyone for your help!
  1. Harmonic balancer
    By dezebe1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2014, 10:19 PM
  2. Harmonic balancer
    By Tone5500 in forum General Tech Discussion
    Last Post: 11-13-2013, 08:01 AM
  3. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  4. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
