Thread: 2002 Grand Prix GTP - I smell oil burning
Results 1 to 8 of 8
  1. #1 2002 Grand Prix GTP - I smell oil burning
    Jan 2015
    Michigan
    Hello,
    I purchased a 2002 Grand Prix GTP on Wednesday and after driving the vehicle for a while (longer than I drove it to test drive it), I smell oil burning. Any risk of the GP bursting into flames or is that issue actually fuel related?
    I am not sure if this vehicle was recalled due to a leaking valve cover gasket. If it was recalled, can I find out if it was repaired somewhere online or would I have to take the car to a dealership?
    Thanks,
    Paul
  2. #2 Re: 2002 Grand Prix GTP - I smell oil burning
    vin # in hand, call a dealer, they can tell you. it only covers the front v/c, not the rear one.
    so its best to just get some de greaser, spray the engine down, top and bottom, hose it. then watch for a leak.
    you can also, car cold, take a paper towel folded up, then wipe under the valve cover lip, if it comes up with wet oil theres your leak. wet dirty spots are also leak areas, or the trail of oil.
  3. #3 Re: 2002 Grand Prix GTP - I smell oil burning
    Jan 2015
    Space coast Florida
    Doubt flames would happen unless it is a major leak. Private seller or from a dealer? If it was a dealer I'd go back and complain and maybe they could help you out.
  4. #4 Re: 2002 Grand Prix GTP - I smell oil burning
    Kemmerer, Wyoming
    that was happening to me a while back, ended up being the oil sending unit and the oil pan leaking. sending unit is an easy repair, oil pan is a bit more intensive. the oil was blowing back and burning when it hit the downpipe.
  5. #5 Re: 2002 Grand Prix GTP - I smell oil burning
    Jan 2015
    Michigan
    I purchased the vehicle from a private owner.
  6. #6 Re: 2002 Grand Prix GTP - I smell oil burning
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by phogstenjr View Post
    The GM valve cover gasket recall campaign suffered from one intractable problem - the GM dealers got lazy and only replaced the front valve cover gasket. Trouble is, the rear one is just as likely to leak.
    Get some valve cover gaskets for like $15 at Autozone/Advance/NAPA/etc and budget an afternoon to do the job right... whatever you do don't get ACDelco gaskets though. Get felpro's. Last time I saw someone put an ACDelco valve cover gasket on his car it leaked like a sieve.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  7. #7 Re: 2002 Grand Prix GTP - I smell oil burning
    Jan 2015
    Michigan
    Ok, thanks for the information. Should anything be done with the fuel lines, as I have read that a leaking fuel line is what is responsible for Grand Prix catching on fire?
  8. #8 Re: 2002 Grand Prix GTP - I smell oil burning
    if it leaks fix it. mine was leaking right on top of the sc. pulled the o rings out the fuel line, and replaced them. no more leaks.
    if its not leaking, dont mess with it.
  1. Grand Prix burning oil smell?
    By Russosaur in forum General Grand Prix Discussion
    Last Post: 05-18-2012, 04:34 PM
  2. Burning smell?
    By mick777wauchope in forum General Tech Discussion
    Last Post: 04-17-2012, 03:40 PM
  3. Getting that burning smell
    By Hockeytown19 in forum General Tech Discussion
    Last Post: 06-10-2010, 02:04 PM
  4. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
  5. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
