Thread: what in the hell is wrong with my radiator
Results 1 to 10 of 10
  1. #1 what in the hell is wrong with my radiator
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    if you drive the car normally it won't get up to temp it'll get halfway about but when you park it and leave it idle it'll get up to temp or pretty close. why? its winter if that helps but i don't think it matters. thanks
    '01 GT, OnStar antenna removed, GT emblem on grille, PONTIAC bumper inlay, engine cover and insulator removed, polished stock exhaust tips, 17" Bullitt rims
  2. #2 Re: what in the hell is wrong with my radiator
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Sounds more thermostat then radiator. What one are you running and how old/many miles is it?
  3. #3 Re: what in the hell is wrong with my radiator
    Sep 2014
    U.S.A
    its the original thermo with 121xxx miles
  4. #4 Re: what in the hell is wrong with my radiator
    its winter. and they all rise when in park sitting after a while, then drop when moving. sounds kinda normal to me.
  5. #5 Re: what in the hell is wrong with my radiator
    GTP Level Member
    Oct 2014
    Yes. Normal. My gauge like to hang at the 1/4 mark while moving.
    Sent from my iPad using Tapatalk
  6. #6 Re: what in the hell is wrong with my radiator
    First big line is roughly 195ยบ anyway, factory gauge is terrible as telling correct temps.
  7. #7 Re: what in the hell is wrong with my radiator
    Nov 2013
    Wisconsin!
    Nothing is wrong with your car....its called winter, colder air means colder engine temps, or increased warm up time.
  8. #8 Re: what in the hell is wrong with my radiator
    GTP Level Member
    Aug 2012
    st louis park, MN
    I would still argue this could be your thermostat. If it were stuck partially open or fully open, at idle the lack of airflow through the radiator would allow the engine temp to rise. At highway speed, the radiator and a stuck thermostat could create an overly cooled engine.
    Sure, engines tend to run cooler in the winter and hotter in the summer but over an extended period of driving at any reasonable air temperature, your thermostat should be able to get your engine to the correct operating temp (assuming you are keeping a relatively similar speed).
    I'd change the thermostat and check your coolant safe temperature.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  9. #9 Re: what in the hell is wrong with my radiator
    Las Cruces, NM
    Quote Originally Posted by stocker View Post
    This. It's too cheap and easy not to try.
  10. #10 Re: what in the hell is wrong with my radiator
    SE Level Member jimzssei's Avatar
    Sep 2014
    My Bonnie runs at 200 when it's below freezing out there. A fresh T,stat made sure of that.
  1. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  2. ion from hell
    By Poil336 in forum Track Sessions and Kills
    Last Post: 06-15-2012, 05:16 PM
  3. Someone has to know what the hell this is
    By Alphaketo in forum General Grand Prix Discussion
    Last Post: 02-04-2012, 09:31 AM
  4. What the hell is wrong with me....
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 09-14-2008, 04:27 PM
  5. Where the hell did this car go?
    Last Post: 09-09-2008, 09:30 AM
