Thread: how do i remove fuel injectors?
Results 1 to 13 of 13
  1. #1 how do i remove fuel injectors?
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    I'm trying to replace my front valve cover gasket. the bolt holding the bracket on over the cover is hard to get to and its right next to an injector. I've tried a normal wrench, i went out and bought a ratchet wrench, and tried a pivot socket. NOTHING WORKS. don't tell me to try again. I've tried enough times to where i don't care anymore. I've decided i need to remove the injectors to get access. how do i do this. don't tell me to loosen the bolts. tell me where and what exactly to do. videos don't help and i can't figure it out myself without breaking stuff. i know the whole fuel rail is gonna come off and the back injectors are gonna too. just tell what exactly i need to do. I'm dumb when it comes to this stuff, clearly
  2. #2 Re: how do i remove fuel injectors?
    For whatever reason, I can't figure out what bolt you are trying to get at.
    Do you have a picture of what you speak of?
    Otherwise to remove the fuel rail, remove the 4 nuts holding the rail down. There is one in each corner on a stud, then with your hands pull straight up and a little bit of force and rail will pop out, do that for each corner then place it off to the side. You will want to inspec the o-rings on the injectors, replace as needed.
  3. #3 Re: how do i remove fuel injectors?
    Sep 2014
    U.S.A
    its n/a and its the bog bone mount on the left side if you're facing the car. I've included a pic, not my engine, you may have to open it in another window
  4. #4 Re: how do i remove fuel injectors?
    Sep 2014
    U.S.A
    ahh, ill go take a pic quick and upload it...
  5. #5 Re: how do i remove fuel injectors?
    are you n/a? and your talking the pass side dog bone engine mount?
  6. #6 Re: how do i remove fuel injectors?
    Sep 2014
    U.S.A
    thanks. its the big brace bracket thing that covers the left side of the valve cover. it bolts next to an injector and somewhere else. its that one bolt next to the
    injector thats impossible to get to. in the pic its both the black dog bone but the metal bracket its bolted to next to the distributor
  7. #7 Re: how do i remove fuel injectors?
    pics not working for me.
  8. #8 Re: how do i remove fuel injectors?
    Sep 2014
    U.S.A
    im retarded and can't upload a pic. anyway it has a torx bit tip on top of the bolt. that should help a lot
  9. #9 Re: how do i remove fuel injectors?
    http://www.dragtimes.com/video-viewe...kiE78U&feature theres a vid, points out and says what wrench to use. dont say anything about take the injectors out.
  10. #10 Re: how do i remove fuel injectors?
    Does this picture show it??
  11. #11 Re: how do i remove fuel injectors?
    Sep 2014
    U.S.A
    he just explained how to do it. he actually didn't remove it so he doesn't know its hard to get to that bolt
  12. #12 Re: how do i remove fuel injectors?
    Sep 2014
    U.S.A
    YES! its the bolt right next to the middle injector hole. literally tight next to it. its dirty in the pic
  13. #13 Re: how do i remove fuel injectors?
    ive hear people ***** about it, its one of them turn the bolt, 1/4 turn, flip the wrench repeat till its finger loose.
    if you really want the rail off, in the 4 corners of the fuel rail where it meets the lim, theres a nut on a stud, remove the 4 nuts, then pull up evenly on the rail pulling the injectors out of the lim.
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. New member trying to remove the fuel injectors
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 06:51 PM
