Thanks for the helpful post matt5112. That sound clip is basically what i am going for. Still trying to decide between 2.5 and 3 inch piping, and which mufflers and resonator.
Resonators are great if you get one with a large volume.
If you're really looking for a good trick, there is this magical solution:
http://www.performancetrucks.net/for...-drone-489463/
Ok so i think i will be going with either dynomax super turbo mufflers or thrush. One of these..
http://www.ebay.ca/itm/Thrush-Welded...d689a8&vxp=mtr
http://www.ebay.ca/itm/Dynomax-Super...cb898b&vxp=mtr
Are these the right style muffler as far as size and inlet/outlet? And is either one better than the other? Thanks in advance.
super turbo and welded are two completely different mufflers. super turbo has 3 big tubes inside, welded is a chambered, which is loud.
offset in/center out yes.
Ok thanks. I might be going with 3 inch exhaust. I am about to order these borla mufflers but i wanted to double check and make sure they were the right ones??
http://www.summitracing.com/parts/bor-40359
yes
No more lurking. We need each and every owner of a w-body to be giving input on what they are doing to their car, so that the shared experience can benefit all owners.
