Thread: TC and ABS Light On
Results 1 to 5 of 5
  1. #1 TC and ABS Light On
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    I just replaced the CV joint (passenger side) which was causing those lights to come on every time I made a turn. Now as soon as I turn the car on both lights come (TC & ABS). How do I take them off or how can I reset them to be off?
    '04 | GP | GT2 | 162K
    Not an Expert | Just for the love of working on cars
  2. #2 Re: TC and ABS Light On
    Aug 2011
    'Merica
    The CV shaft wasn't causing the lights. The ABS/TC sensor is in the hub and likely has gone bad. You will need to replace the hub to make the lights go away. If you know what side the lights are from you can check the wiring to the sensor to see if there are any broken or cracked wires.
  3. #3 Re: TC and ABS Light On
    if you cant find a damaged wire to the hubs, or a loose hub, its best to have it scanned at a shop.
  4. #4 Re: TC and ABS Light On
    Aug 2011
    'Merica
    I don't think the scanners at the local auto parts stores read those kinds of codes, do they?
  5. #5 Re: TC and ABS Light On
    some times a good engine scanner will pick up abs codes on the newer cars, not always tho. the autozone scanner picked up a abs code on my friends 05 gm truck.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
