Just the little motor thingy in the fuel pump
looks like 2 screws. unplug it, and pull that line off.
most come apart with little thinking, id work on the canister you dont need. that way if you break something its not the canister you need and you can learn on it.
that last hose looks like it just pushes over the nipple there.
with a pair of pliers twist the line back and fourth till it moves on the pump, then wiggle it off.
work on the one you cut first, twist it loose.
when you buy a new pump it comes with this hose new. so be careful if its brittle feeling.
a little wd-40 cant hurt, dont flood it tho, like inside the pump.
pic of a new pump, the hose slips on the pump.
http://www.highflowfuel.com/i-521003...1997-2000.html not sure your year, but this looks close.
not on its own. like i said that would come with the new pump, and local parts stores seem to no longer sell just the pumps kits.
work as easy as you can, twist it, then wiggle and pull up on it.
Wbody store or ZZP sells the corrugated hose part individually. http://www.wbodystore.com/air-induct...tank-hose.html
You know... In case it breaks.
