Thread: How much horsepower can I pull from an N/A 3800?
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 How much horsepower can I pull from an N/A 3800?
    SE Level Member keonmakesbeatz's Avatar
    Aug 2014
    I heard somewhere that it wasn't much. I just want to know if I NEED to top swap it to make it fast.
    I'm a noob so 300 horsepower is my goal for MY first build. Is this achievable? Am I shooting for the stars?
    Also, there was a guy that stated "The conrods on the series 2 3800 are weaker than the crank and over time, the conrods will have turned into a slight oval" or something like that. Is this true? If so, I might have a bad engine (Not to sure on the condition of the engine but the previous owner didn't take care of this car at all [70 mph average with a clogged cat, bad bearings, random misfire, slipping transmission, and dexcool in the system])
  2. #2 Re: How much horsepower can I pull from an N/A 3800?
    Engines are cheap enough if you throw a rod then you throw a rod just be prepared for a swap if the time comes.
    Your not going to make 300hp on a n/a setup. You better either be prepared to topswap or go turbo..
    04 Comp G.
  3. #3 Re: How much horsepower can I pull from an N/A 3800?
    Aug 2014
    Engines are cheap
    I didn't expect you to say that. That's the first time I've seen "engine" and "cheap" in the same sentence. Haha
    Ahhhhhh I didn't want to hear this. Oh well, it is what it is. I love the way turbos sound so I'd go with turbo. Isn't there a lot more work with adding a turbo than there is with adding an S/c ?
  4. #4 Re: How much horsepower can I pull from an N/A 3800?
    Since you aren't charged, a turbo is almost easier.
  5. #5 Re: How much horsepower can I pull from an N/A 3800?
    Aug 2014
    Keyword: almost
    So overall it's pretty much the same? No fabrication work?
  6. #6 Re: How much horsepower can I pull from an N/A 3800?
    A turbo.. you bolt on the turbo, add the pipes, waste gate etc etc, put on an intercooler, tune it. and go faster, easier than a top swap
    Topswap... you remove the entire upper end of the engine, bolt new parts on, and tune it.
    I'm simplifying.. but the point is made... a turbo is easier, faster and you'll change no gaskets on the motor.
  7. #7 Re: How much horsepower can I pull from an N/A 3800?
    Aug 2014
    Oh! Tuning! Where can I go to learn how to tune myself? Or is that to extensive?
    Also, no supporting mods? Wouldn't I need to like weld a flange onto the crossover or something like that?
  8. #8 Re: How much horsepower can I pull from an N/A 3800?
    But turbos also cost quite a bit more then a topswap will., unless you can fab and weld then you can fab a setup for a good price.
    04 Comp G.
  9. #9 Re: How much horsepower can I pull from an N/A 3800?
    Banned
    CT
    I remember a long time ago a local guy here in CT had an all out n/a 3800 build. The works.
    IIRC he spent about $5,000 on mods.
    It made like 220whp lol
  10. #10 Re: How much horsepower can I pull from an N/A 3800?
    Aug 2014
    Quote Originally Posted by SnowFlake View Post
    Oh my gosh HAHAHAHAHAHHAHAHHAHA
    That really sucks
    Why did he do it though? Preparing it to be boosted or something?
  11. #11 Re: How much horsepower can I pull from an N/A 3800?
    Say you buy this.... http://www.grandprixforums.net/threa...00-Finders-Fee
    And you'd pretty much be bolt and go
  12. #12 Re: How much horsepower can I pull from an N/A 3800?
    Aug 2014
    The Purpletraitor? I was just watching videos of that car. That's crazy! But that's pretty cool!
    I thought I would have to do the cam, rockers, pushrods and other things of that nature. Good to know I don't have to, tho I probably will.
  13. #13 Re: How much horsepower can I pull from an N/A 3800?
    Well.. the turbo kit is for sale. You don't have to do anything else. A stock motor is amazing with a turbo, add a cam or rockers down the road and you have a heck of a fun ride til the trans goes south.
    Ain't that right about trans issues Snowflake?
  14. #14 Re: How much horsepower can I pull from an N/A 3800?
    contact greg aka gmrbadass for said turbo kit or anything else 3800/wbody performance related good chance hes got what your looking for.............HA
  15. #15 Re: How much horsepower can I pull from an N/A 3800?
    Tell him Bill sent ya.. since he's offering a finders fee lol
  16. #16 Re: How much horsepower can I pull from an N/A 3800?
    whoa whao whao you just sent the link...... tell him TYLER sent ya greg can just knock the fee off my already large tab.......
  17. #17 Re: How much horsepower can I pull from an N/A 3800?
    Quote Originally Posted by 9898GrandPrixIraqFLVet View Post
    I'm going to change your name again.
  18. #18 Re: How much horsepower can I pull from an N/A 3800?
    Never Never Land
    Highest N/A 3800 i've seen is this one.
    http://abbottracingheads.com/gm3800.htm
  19. #19 Re: How much horsepower can I pull from an N/A 3800?
    Aug 2014
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Seems like a lot of mods . Why do that if you can just top swap it?
    those mods would be better for if you want like 500whp but I only want like 220-260whp.
  20. #20 Re: How much horsepower can I pull from an N/A 3800?
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by keonmakesbeatz View Post
    A top swapped GT with some headers and a stock pulley will get you close to 220. Throw some 1.9 rockers on there to make sure you get there. Or intercool, drop 3-4 pulley sizes, and get more like 260.
    It's probably cheaper to just do an L67 swap than a top swap once you factor in the head gaskets, bolts, etc. I've got the heads, fuel rails, blower, ignition bracket, and throttle body sitting on my shelf and it will still cost me another $400 easily to make it a ready to go set.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  1. Horsepower?
    By JonnyGrandPrix in forum General Grand Prix Discussion
    Last Post: 02-28-2012, 05:08 PM
  2. Adding horsepower??
    By TeKmInIbI in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2011, 07:43 AM
  3. Handling 550 horsepower
    By deathjunior in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-18-2011, 02:58 AM
  4. Need more horsepower
    By csssaint12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 08:10 PM
  5. how much horsepower u think ill make
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2008, 08:31 AM
