Hey thanks for the help guys! So I found my issue, it was a break in the wire.
When I first got my car I had an issue with the coolant level sensor always reading low. So I found a short in my harness where the wire broke from rubbing against the radiator cap. I repaired it but the sensor never did work.
Turns out that it wiggled it's self loose and it was actually my injector wire.
Problem solved!
Thanks again!
