Thread: Not so new, but first post...
Results 1 to 5 of 5
  1. #1 Not so new, but first post...
    Jul 2010
    Michigan
    So my wife has an 02 GT. Until last month it had been sitting for about 9-10 months. The battery was completely shot, bought a new one and the car started up flawlessly. However, I noticed the smell of oil burning. I opened the hood, and seen smoke coming from the front side of the motor (Front side of the car). I replaced the VC gasket thinking that it was probably in need. However, it still smokes. I cleaned it all up using engine degreaser. I thought it may just be burning off what was left. THat's not the case, it is still doing it after about a hundred miles. Does anyone have any thoughts. It has about 170k miles but has had regular oil changes and had the plugs and wires changed at about 150k along with the coolant elbows. I haven't noticed any coolant in the oil nor am I losing any either. Any help would be appreciated.
  2. #2 Re: Not so new, but first post...
    Apr 2014
    CT
    mine was leaking from the lower manifold gasket ontop of the tranny and then running down back of tranny.
  3. #3 Re: Not so new, but first post...
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Is it oil thats leaking? You cleaned up the mating surface really good right?
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: Not so new, but first post...
    Did you get new valve cover grommets?
    Maybe a bad gasket aswell.
  5. #5 Re: Not so new, but first post...
    Jul 2010
    Michigan
    It's definitely oil due to the smell. I cleaned it very thoroughly while the VC was off. I didn't get new grommets, but the gasket was changed. Maybe I should've gotten them, thought they were good...maybe not.
  1. Another what's this post
    By 94grandprix in forum General Grand Prix Discussion
    Last Post: 05-19-2014, 10:43 PM
  2. Do you have to post here before you post in forsale?
    By blank77 in forum Introductions/Noob Questions
    Last Post: 04-10-2013, 03:17 PM
  3. First post.
    By ebengt02 in forum Introductions/Noob Questions
    Last Post: 12-18-2012, 10:10 AM
  4. side post to top post conversion
    By arcadeguest in forum General Tech Discussion
    Last Post: 01-12-2012, 01:09 PM
