Thread: New Member with car trouble
Results 1 to 9 of 9
  1. #1 New Member with car trouble
    May 2014
    Albuquerque, New Mexico
    Hello everybody, this is my first post so please excuse any poor manners on my part. I have a 2001 GT 3.8l and I'm having a bit of trouble. I have been having an issue with the car dying its been going on for about 4 months and has progressively gotten worse. It started out as the car stalling every now and then and starting right back up usually. Now it has progressed to the car dying after about 15 mins and not wanting to start. At this point I have replaced the crankshaft sensor, the camshaft sensor, knock sensor, spark plugs, fuel pump, fuel pressure regulator, and coolant temp sensor. I'm pulling my hair out!
    Edit: It seems to be worse when going up and incline. Generally the going up will cause it to die pretty quick.
  2. #2 Re: New Member with car trouble
    double check the crank sensor harness. and theres always a chance the crank sensor is bad. new parts out of the box being bad happens time to time.
  3. #3 Re: New Member with car trouble
    Feb 2013
    37.295091, -121.930053
    well are you getting any codes? that would be a big help
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: New Member with car trouble
    May 2014
    Yea, I went to O'Reillys to get the codes checked and I got codes for the Cam sensor, Crank Sensor and Knock Sensor.
  5. #5 Re: New Member with car trouble
    id give the harness a good checking for damage. being you changed all that pretty much.
    have you cleared the codes since changing the parts?
  6. #6 Re: New Member with car trouble
    May 2014
    We checked it when we were under there before. Being that it took forever to get to it lol. I'm just really out of ideas. The only thing left to do I can think of is change the fuel filter.
  7. #7 Re: New Member with car trouble
    ever clear the codes?
  8. #8 Re: New Member with car trouble
    May 2014
    Yep. Cleared them about a week ago. It's been off since then. Ironically enough, I just started the car and it clicked on tho.
  9. #9 Re: New Member with car trouble
    figures right.
    check the grounds on the tranny bell housing, and the icm ground on the side of the head under the coil bracket.
  1. Please help having trouble with 04 GTP
    By Grandprixtennessee in forum General Tech Discussion
    Last Post: 12-07-2012, 02:34 PM
  2. car trouble Help please
    By grandprixxx94 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-29-2011, 07:13 AM
  3. what car Gets you in the most trouble???
    By KwazrollinZ28GTP in forum The Rant Forum
    Last Post: 12-18-2010, 01:54 PM
  4. NEW MEMBER Trouble
    By msmoot in forum General Tech Discussion
    Last Post: 12-17-2010, 06:43 PM
  5. S/C Trouble...
    By LaCabra in forum General Tech Discussion
    Last Post: 04-01-2009, 09:45 PM
