hi everyone. I think i may have a good one. i have a 1997 grand prix gt. no spark excellent fuel pressure.my issue is i was checking the ecm for continuity at the pink wire which there was none. after looking for the problem, i found there is a short at that wire. i connected the clip from my test light to neg. post on battery and found power at the pink wire. just changed out the under hood relay center figuring it was that. still the same. but the strange thing is it has that short even with the ignition off.Im also finding that all the pink wires are doing this. even at the injectors.is there something im missing? has anyone had this problem and found out what it was? ant help would be appreciated. thanks.
