Thread: help! hard start after overkill pcm install
Results 1 to 20 of 30
  1. #1 help! hard start after overkill pcm install
    Enfield, CT
    Alright guys I installed the overkill pcm and followed all the instructions Will sent. The car drives and shifts so good but I'm having an issue with the car hard starting every time and this did not happen before the pcm swap. I did remote start it after I manually started the car a few times and the remote start is normal. The weather here is 51 degrees so it warm for Massachusetts today. Any help would be appreciated
  2. #2 Re: help! hard start after overkill pcm install
    Mar 2012
    NC
    It might still be learnng. Give it a few days and see if it gets better. I really have no idea though and hopefully someone else will have a better answer.
  3. #3 Re: help! hard start after overkill pcm install
    Enfield, CT
    alright I'll try that. Will post if it does not help. thanks
  4. #4 Re: help! hard start after overkill pcm install
    Mar 2012
    NC
    No problem.
  5. #5 Re: help! hard start after overkill pcm install
    Florida
    My overkill PCM did that for the first few starts. Thought something was wrong. Left the battery unhooked for 30mins or so, and left the key on (to drain any residual power) Hooked it back up and same thing. After a good "spirited" drive (10-15 minutes) it never had that hard starting again. It actually started much faster than normal (though Will states he has his PCMs setup for his 'quick start')
  6. #6 Re: help! hard start after overkill pcm install
    every time i un hook my battery long enough to clear a code say, the pcm needs to re learn. the first start the engine will crank like 3 times before it fires up. never did it more then once tho. same with the tranny, its learning how you drive. it may shift hard or firmer then you like for a day or two.
    new pcm, id think its still learning.
  7. #7 Re: help! hard start after overkill pcm install
    Enfield, CT
    I didn't mention that I put the ZZP alternator power cable on as well but I put that on after the first time I started the vehicle. I don't think the cable is the culprit due to it hard starting before I installed it
  8. #8 Re: help! hard start after overkill pcm install
    Enfield, CT
    Took the car out for another spin and it started perfectly 3 times in a row. You guys were right about the pcm still learning. thanks
    I'm gonna jack my own thread here lol. I know the ZZP alternator rewire is supposed to boost the voltage but is it ok for the car to be running at 15 - 15.10 volts while driving? Normally the car runs at 14 - 14.5 volts
  9. #9 Re: help! hard start after overkill pcm install
    Honestly I've had terrible luck with ZZP booster draining the hell out of my battery I removed it and problem free my car stays around 14.5 volts or so
    04 Comp G.
  10. #10 Re: help! hard start after overkill pcm install
    Enfield, CT
    Yea I thought about removing it but I put it on because I had it for my '97 and it was just sittin there. The windows seem a little slower now too. I'll think about it lol
  11. #11 Re: help! hard start after overkill pcm install
    Florida
    Strange. I've had 2 of them, one on my old GTP one on my current.
    Had nothing but good luck with them. Constant 15.1V -15.2V Windows went up more quickly, and the lights didn't fade when you'd open/close the windows at night. Though doing the Big 3 helped a bunch too.
  12. #12 Re: help! hard start after overkill pcm install
    Enfield, CT
    Is the Big 3 the same on 04+ or different?
  13. #13 Re: help! hard start after overkill pcm install
    Florida
    For 99% of cars it's all the same.
    Run new power wire from Alt to fusebox, and fusebox to battery.
    Run new battery ground to chassis
    Run new engine ground to chassis
    I did mine with 4gauge. I wouldn't go any smaller. Though you can go as big as you want.
  14. #14 Re: help! hard start after overkill pcm install
    Enfield, CT
    pics lol
  15. #15 Re: help! hard start after overkill pcm install
    Florida
  16. #16 Re: help! hard start after overkill pcm install
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Not to thread jack but wouldn't you want to run fuses between alt and batt. Or from alt to fuse then one from fuse to batt?
    Sent from my Galaxy Tab 3
    2012 F150 STX
    - Gonna be a race truck
  17. #17 Re: help! hard start after overkill pcm install
    why? its power to power. ground to ground
  18. #18 Re: help! hard start after overkill pcm install
    Apr 2012
    Dayton, OH
    Iv always been told at least from batt to whereever fuse box or alt you want a fuse for if something shorts.
    2012 F150 STX
  19. #19 Re: help! hard start after overkill pcm install
    Florida
    Yep, best to run a fuse between the alt and the battery/fuse box. If the alt starts to over-charge it'll save your electrical system. I wanna say I have a 140amp fuse in mine, but I could be wrong.
  20. #20 Re: help! hard start after overkill pcm install
    cant see why it would matter, the factory lines are not fused at all. its just cables. so you are only putting thicker cable in place of the stock cables.
  1. Overkill pcm install help?
    By szalajka05 in forum General Tech Discussion
    Last Post: 11-13-2013, 02:21 AM
  2. Car wants to die after overkill install..
    Last Post: 05-30-2012, 01:34 PM
  3. Overkill PCM now Stalling rough start
    By kyleinkman in forum PCM Tuning
    Last Post: 10-25-2011, 07:26 PM
  4. How hard is it to install HUD?
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 12-15-2010, 09:14 PM
  5. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
