Thread: HS 1.9 RR question
Results 1 to 19 of 19
  1. #1 HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    Dumb question on the HS rockers, i got a kit from another member last week, but have no idea which way the mounts are supposed to be facing, grove up or down? and what is the piece in the bottom right corner of the image?? thanks for any help guys
  2. #2 Re: HS 1.9 RR question
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    The way you have it on the lower one. Raised edges up.....The "pedistal" slides into the groove of that plate.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    Awesome, thanks man. Any idea about the piece on the bottom right side?
  4. #4 Re: HS 1.9 RR question
    Jun 2012
    south haven mi
    stands for the rockers they fit in the grooves on the plate
  5. #5 Re: HS 1.9 RR question
    Apr 2011
    Columbus, OH
    If you wan installation instructions or someone local to show you how they go on just hit me up. Very simple and I don't mind showing you how to change out rockers and springs
    Springs will need to be done especially if you want a turbo kit
  6. #6 Re: HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    Hell yea, that would be awesome, I got this **** valve spring compressor and keep on dropping the damn valve spring retainers. I already know I'm gonna end up throwing tools changing the rear springs.
  7. #7 Re: HS 1.9 RR question
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Use a magnet. Makes life a LOT simpler.
    First you put the plate with the machined side up (groove cut in it) then you put the pedestal on there (piece in the bottom right corner) then you install the rocker with the flat side of the fulcrum (piece in the middle of the rocker with a hole in it that spins) facing up, then install the bolt.
    Sent from Not so smart smartphone
  8. #8 Re: HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    Awesome, thanks. Any idea where I can find this tool aside from online (wanting to finish asap)
    http://www.amazon.com/gp/aw/d/B008FJ...dir_mdp_mobile
  9. #9 Re: HS 1.9 RR question
    Jul 2013
    Summertown Tn
    What do you need that for? Just get a pocket magnet from the parts store. When you start reinstalling don't try putting both locks back in at the same time.
  10. #10 Re: HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    The only problem is with the spring compressor I don't have any room to fit a magnet,
  11. #11 Re: HS 1.9 RR question
    Jul 2013
    Summertown Tn
    Well you damn sure wouldn't have room for that keeper tool.
  12. #12 Re: HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    The keeper tool has a built in magnet that holds them in place while I compress the spring
  13. #13 Re: HS 1.9 RR question
    Jul 2013
    Summertown Tn
    Yea, I know how they work. I own one and its useless.
    But you said you didn't have room for a pocket magnet.
    If you use a pocket magnet it'll work just as good as a useless tool added to the toolbox.
    Btw, the keepers aren't going to just fall out of the retainer when you compress the spring.
  14. #14 Re: HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    So I finally finished up my rocker install, any guess around what I'm sitting at now power wise?
    Mods are: HS 1.9 RR's, LS6 springs, oil restricted pushrods, ZZP powerlog, ZZP uncatted downpipe, 160* tstat, 3.4 MPS.
    Getting a full tune next week but just curious around what I will be at
  15. #15 Re: HS 1.9 RR question
    Mar 2012
    NC
    240ish WHP?
  16. #16 Re: HS 1.9 RR question
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    230-240 whp maybe.Why so low of a t-stat?
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  17. #17 Re: HS 1.9 RR question
    Feb 2014
    Westerville, Ohio
    I only run it in the summer. I have my Honda for winter driving. I might go 180* because having 3 cars is getting pricey
  18. #18 Re: HS 1.9 RR question
    Maybe 225-230whp, maybe.
  19. #19 Re: HS 1.9 RR question
    Quote Originally Posted by DrakV2 View Post
    maybe put the stock 195 t stat back in and save some more gas. your engine hates you for this t stat. even in the summer time, its doing jack sh it.
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
