Hello i joined back up with this forum bc i need some help i just bought me a new 02 GTP and im wanting to build it to make it run at least 10s in the quarter if possible does any one have any ideas on what i need to do to achieve this goal.
Turbo, heads, cam, built trans.
theres a guy here with a 10 second gtp. its turbo with a built tranny, and it seems to beak the tranny all the time. input shafts nap off real easy, even the good ones.
once you hit 10 seconds you had best have a roll cage in the car, cause your not running any more with out it. not at a real track any way.
Pretty sure that dude's car puts down over 500whp, good luck getting into the 10's.
Think 13's before you are out more money than the car is worth, because a built trans that can handle that power is over $3,000.
think the real question is, do u want to dump that much money into a 02 gtp? IMO id use that money and go v8, but again thats just my opinion
EDIT: best of luck tho man
Yea might want to set your expectations lower. What I mean is it won't be cheap or easy..heads,cam,Turbo and more important a built trans that won't shatter after each pass will not he cheep at all.
10's for a daily driver? You bought wrong wheel drive. I love them but you need more cylinders, better transmission and RWD.
Ok then maybe tens won't b possible... what are some good internal things to do so I can put a smaller pully on my super charger
Sent from my HUAWEI H881C using Tapatalk
Or what swaps are there that I could do
Start reading Mr 10's
Safely Modding Your 3800! http://www.grandprixforums.net/showthread.php?t=67580
Leave the internals alone.
Sent from A Galaxy Far Far Away........
