Yes hub is detached from knuckle and moving, but only slides off shaft part way and stops. Actually once the back 3 bolts and center nut are off the shaft might be moving outward "with" the hub at this point. OK I will try again this up coming weekend. Everything else came off relatively easy once bolts were off. Even the bolts were pretty easy. With that said I was really surprised to have this happen. I had a feeling it was just being difficult. I could not see anything else holding it other than the splines on the shaft. I will try to pop the center shaft with nut on end again. Prior I removed the bolts I put hub back into knuckle and hit end of shaft but didn't want to hurt the cv joints ect... Must not have hit it hard enough. I appreciate the help.
