First off, I'm assuming it will crank, but not start, correct?
Do you hear your fuel pump running when you turn the key to run? You can check to make sure you're getting fuel at the rail by pressing the schrader valve.
You said you replaced your crank sensor, but does your rpm's go up when cranking? (to around 200)
Check for spark, pull a wire off the coils and see if it arcs across to another terminal or to ground.
