Thread: car wont start
Results 1 to 2 of 2
  1. #1 car wont start
    Apr 2013
    Union City, In
    i have a 99 gtp 150k miles
    i have replaced fuel pump filter crank sens and bent relay tab. it ran for one night now it wont start any ideas?
  2. #2 Re: car wont start
    Dec 2012
    Where 4T65E's were born
    First off, I'm assuming it will crank, but not start, correct?
    Do you hear your fuel pump running when you turn the key to run? You can check to make sure you're getting fuel at the rail by pressing the schrader valve.
    You said you replaced your crank sensor, but does your rpm's go up when cranking? (to around 200)
    Check for spark, pull a wire off the coils and see if it arcs across to another terminal or to ground.
    Sold.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. car wont start
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 05:56 PM
  5. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
