Thread: Tranny leak and tranny code
Results 1 to 9 of 9
  1. #1 Tranny leak and tranny code
    Aug 2013
    ny
    ok got a leak by front by right fender , tranny fluid. Now got a solinoid code saying permotmace shift stuck
  2. #2 Re: Tranny leak and tranny code
    Aug 2013
    ny
    Any clue what I can do
  3. #3 Re: Tranny leak and tranny code
    Dec 2013
    Indianapolis
    Replace shift solenoid to start.
  4. #4 Re: Tranny leak and tranny code
    Aug 2013
    ny
    What does that entail
  5. #5 Re: Tranny leak and tranny code
    do you mean "performance shift" aka perf shift on the dash is stuck on? what code came up?
    the leak sounds like the line where it meets the rad is leaking.
  6. #6 Re: Tranny leak and tranny code
    Usually if you have a code for "performance" anything it's TCC lockup issues not a perf shift ...
  7. #7 Re: Tranny leak and tranny code
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    I vouch for that^ X2
    mine said shift solenoid when my torque converter died/ exploded.
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  8. #8 Re: Tranny leak and tranny code
    Aug 2013
    ny
    So what do I do
  9. #9 Re: Tranny leak and tranny code
    Start off by answering the question. What was the code
  1. Tranny leak fixed!
    By LS2 BLAZER in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-13-2013, 11:39 PM
  2. Tranny leak out of breather valve
    By 2000gtpbt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-15-2012, 03:55 PM
  3. 2001 GTP tranny fluid leak
    By pcengine92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-24-2012, 02:19 PM
  4. Tranny Leak question
    By Kenny75k in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-23-2011, 08:42 AM
  5. Help!! BIG tranny leak!!!
    By MidnightBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2011, 02:54 PM
