Thread: water?
Results 1 to 8 of 8
  1. #1 water?
    Nov 2013
    new port richey
    hi guys,
    got a 05 gp, sounds like water is splattering from side to side when i accelarate or steer. nothing is wet inside, floor dry, ac drain is free too. any ideas what that could be?
  2. #2 Re: water?
    Nov 2012
    Madison
    gasoline?
  3. #3 Re: water?
    Air in the coolant system
  4. #4 Re: water?
    typically thats air in the heater core. hows your heat working?
    take the 2 heater hoses off the alt bracket, then flush with a garden hose through either hose till a full stream of water comes out the other hose, put the hoses back on.
  5. #5 Re: water?
    Nov 2013
    new port richey
    heat works, is not very hot though, let the heat run for 30 min but its not gone.
    shouldnt the air come out from the water pressure when the heater is used?
    Heli
  6. #6 Re: water?
    make sure it's filled up all the way. Back flush the heater core and then bleed the air out of the system.
  7. #7 Re: water?
    the way your heat works is theres a small radiator in the dash coolant passes through it, when you turn the blower fan on, it pulls the hot air from the rad. if this rad/heater core has air in it theres not going to be good heat, if any at all.
    flush your core like i posted above. its air bound for sure.
  8. #8 Re: water?
    Nov 2013
    new port richey
    Thanks for your Help, gonna try this today.
    heli
  1. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  2. Do you run distilled water or water out of the tap in your cars?
    By Slick2500 in forum Off Topic Discussion
    Last Post: 10-14-2012, 10:59 AM
  3. Water in car
    By hockey101 in forum General Tech Discussion
    Last Post: 08-07-2011, 08:51 AM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  5. Water, water, everywhere!
    By TheDesertFox in forum General Tech Discussion
    Last Post: 06-20-2009, 02:23 PM
