No I didn't replace the uim. Just a new gasket set. Ran the car and it still didn't seem right so i took it apart again and the lower was filled with coolant again. If I am thinking this through correctly then either the composite upper has a crack somewhere and I didnt see it or else it would be warped because if I didnt do the lower properly it would just go into the motor and not flood the manifold right?
