tcc is inside the transmission. sounds like its not the problem.
flashing check engine light usually means multiple misfires. its either you need a tune up real bad, or ignition coil or icm is bad or the cat is clogged up.
if you can get the code read that would help, should be a stored code from the flashing cel.
