Thread: Noob with Surging and Dying problem on startup when hot
Results 1 to 5 of 5
  1. #1 Noob with Surging and Dying problem on startup when hot
    Oct 2013
    I have a 2000 3.8 naturally aspirated. Problem is that after it warms up it surges and dies when starting. Fuel pump, MAF sensor and IAC are new. Replacement MAF sensor is a new Delphi part from Amazon that was put in 4 months ago. IAC was replaced one week ago. When each of these items was replaced, it seemed to help the problem for a little while, but it really has not fixed the issue. No apparent vacuum leaks. Once its running, the MAF sensor appears to read in the correct range (around 5gms/sec) and is steady. It also appears to react correctly when revs are raised. Fuel pressure is at 40 psi and does not surge or drop on startup. If MAF sensor is unplugged on hot startup, the car will start and surge 2 or 3 times but it won't die like it does with the MAF plugged in. I've checked battery voltage which is okay. Air cleaner is not restricting air flow. I've removed the new MAF sensor and cleaned with with no change. Once the car starts and settles down, (by holding rpm at higher level with the throttle) it runs and drives fine. Is the MAF sensor not reacting quickly enough? Is the PCM not sending signals to the MAF quickly enough? No trouble codes are present. I'm most inclined to think that I have infant mortality on the MAF sensor.
    Update as of July 2014 - I have to say I have been surprised that no one has run into this issue before and has an answer to the issue. Fortunately, we had a long cold winter in Wisconsin this year and the surging has not been an issue in the colder weather. This spring I had to replace the AC condenser so I took the opportunity to do a really good coolant system flush on the engine. Even then, I've noticed that now that its gotten warmer, there has been some evidence of the surging. I just replaced the after catalytic converter oxygen sensor since it was shot, and so far, there has not been evidence of surging.
    Last edited by 3rd Uppper Intake; 07-05-2014 at 07:17 PM. Reason: Update of information
  2. #2 Re: Noob with Surging and Dying problem on startup when hot
    Banned
    Oct 2013
    Moorhead, MN
    Lots of possibilities, but I doubt it's intake.
    Egr valve clogged? Vacuum leak? Starter Solenoid? Battery/alternator connection?
  3. #3 Re: Noob with Surging and Dying problem on startup when hot
    Oct 2013
    I don't think that this reply was related to the issue that I brought up.
  4. #4 Re: Noob with Surging and Dying problem on startup when hot
    what about the fuel pressure regulator? it ever stall after it fires up first thing in the morning?
    pull the vac line off the fpr see if gas comes out, or if it smells of gas.
    that guy up there was banned for dumber crap lol
  5. #5 Re: Noob with Surging and Dying problem on startup when hot
    Oct 2013
    Thanks for the reply. Last summer I did buy a fuel pressure gauge and checked the fuel pressure while it was surging, but its worth a recheck. After reading your reply, I went out to check the fuel pressure regulator on startup, but something must have fallen off of my fuel pressure gauge in storage because it no longer pushes the poppet in on the fitting on the fuel rail. I'll have to go by Harbor Freight and see what I am missing out of the hose. One of the disadvantages of buying at Harbor Freight, but otherwise I probably would not have a fuel pressure gauge. I did take off the vacuum line and there wasn't any fuel or fuel smell.
  1. Trouble starting, dying, and surging
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-23-2012, 03:27 PM
  2. Rough, surging idle at startup
    By MacGyver in forum General Tech Discussion
    Last Post: 05-06-2012, 08:25 AM
  3. Problem car bogging after startup
    By Shang TI in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2010, 04:22 AM
  4. Surging on cold startup / down on power
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-15-2010, 03:07 AM
  5. Intermittent dying problem with 00 GTP
    By ls6velless454 in forum General Tech Discussion
    Last Post: 04-08-2010, 12:11 PM
