Thread: I am thinking about picking up an '04 comp G GTP. What are the common issues?
Results 1 to 8 of 8
  1. #1 I am thinking about picking up an '04 comp G GTP. What are the common issues?
    Sep 2013
    Indiana
    Like the thread title says I am looking at picking up a clean and what looks to be a well maintained '04 comp G GTP. What are the common issues these have? It is a good year to purchase? Are they fairly reliable? It will be my winter and bad weather car.
    It has a 158k on the clock on 45k on a new transmission. I am told it was almost all highway miles. But everyone says that.
    Thanks in advance for the help guys. I don't know **** about these cars.
  2. #2 Re: I am thinking about picking up an '04 comp G GTP. What are the common issues?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Lower intake manifold gasket is still plastic.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  3. #3 Re: I am thinking about picking up an '04 comp G GTP. What are the common issues?
    Sep 2013
    Indiana
    Would the mileage scare you off at Wolves? Or are these motors good for a long time like the LS based motors I am used to?
  4. #4 Re: I am thinking about picking up an '04 comp G GTP. What are the common issues?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Quote Originally Posted by 2000SS1979 View Post
    The motor is a 3800 Series III L32 which has the upgraded GenV supercharger which is a plus if you want a little extra power. However you will have to burn premium gas in that car. The motor itself should be as good as any other 3800 with those many miles. A lot of people on here have way over 200,000 miles on 3800's. If I was looking for a bad weather car I'd want to burn regular gas but that's just me.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  5. #5 Re: I am thinking about picking up an '04 comp G GTP. What are the common issues?
    Sep 2013
    Indiana
    Ha. All I own is go fast cars. So even my winter car will need some good fun power. I currently have a Vorteched 2014 5.0 and a '98 Camaro that is built front to rear with a turbo. Besides, who doesn't love a little extra power?
  6. #6 Re: I am thinking about picking up an '04 comp G GTP. What are the common issues?
    Washington Michigan
    Sounds like its a good fit for you then! If the price is right go for it
  7. #7 Re: I am thinking about picking up an '04 comp G GTP. What are the common issues?
    Lim gasket, coolant elbows, vc gaskets probably need changing. onstar antenna tends to leak, all are easy fixes.
    04 Comp G.
  1. Issues with SLP Powerflo install.....Common?
    By rodguezsciii in forum General Tech Discussion
    Last Post: 03-24-2013, 09:17 PM
  2. 04 comp g dic calendar issues, anyone else notice this?
    By Ace in forum General Tech Discussion
    Last Post: 09-07-2012, 12:36 PM
  3. 2004 gtp comp g engine shut off issues
    By jgomori in forum Introductions/Noob Questions
    Last Post: 05-23-2012, 07:20 PM
  4. Common issues w/5.3L GXP cars?
    By NewCar in forum 5.3L V8 (LS4)
    Last Post: 05-05-2012, 06:04 PM
  5. oil pressure issues?common or not?
    By strykergxp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2010, 06:18 PM
