Thread: throttle problem
Results 1 to 3 of 3
  1. #1 throttle problem
    Apr 2013
    Union City, In
    jus changed lim gasket. started car letting it run and whenever i hit the throttle it goes up normal but comes back down extremely slow and has got stuck a couple times i had to go to throttle body and push it back. and at idle it reve up to 1300 then back down to a 1000 wont go below a grand andyone know whats up?
    99 gtp
  2. #2 Re: throttle problem
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    any resistance in the throttle cable?
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  3. #3 Re: throttle problem
    Sounds like a vacuum leak.
  1. Throttle problem??
    By jman44 in forum Introductions/Noob Questions
    Last Post: 06-15-2013, 12:11 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. throttle body/lim bracket problem
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2010, 05:04 PM
  4. throttle problem?
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-17-2008, 07:58 AM
