Thread: 2004 Grand Prix GTP (SC)---Diagnosis help.
Results 1 to 8 of 8
  1. #1 2004 Grand Prix GTP (SC)---Diagnosis help.
    SE Level Member razorx92's Avatar
    Apr 2013
    Presque Isle, ME
    Car Specifications:
    2004 Grand Prix GTP (Supercharged)
    3.8L SC
    93,600 Miles.
    Im sick of playing guessing games with the shop. First they told me my transmission needed to be flushed. During the flushing they said to check if I see any shavings. I found nothing while watching the garage do the flush. After this flush, my shifting improved, but thats about it. Any ideas of what I should have checked or maybe even what the problem may be? This car has been named "Pegasus" because it seems impossible to figure out the issue. I will say that I have a hunch that im slowly saying good bye to my transmission, but im not about to spend a ton of money unless someone else can back that idea up. Also, anyone know if this is a common issue with these cars?
    Problem:
    1.) Weird Grinding/ Vibration coming from the front towards the center of the dashboard on the floor.
    2.) Sounds and feels like misfiring (NO CHECK ENGINE LIGHT)
    3.) Start up, runs perfectly for 5 seconds, then bogs down and almost stalls, then resumes perfect running (intermittent issue)
    4.) ONLY WHEN TURNING, sometimes the car will rev high without accelerating to match. Then out of nowhere a big burst of power (intermittent issue)
    Known Issues:
    1.) Strut mount in the front = Binding (Probably not related to the above)
    2.) Needs a brake job. (Rotors are very shot. aswell as the pads, not sure about calipers....)
    What I've Fixed while trying to figure this out (everything fixed has been suggested by a garage, but done by me, except whats specified.)
    1.) Spark Plugs and Wires
    2.) Transmission Flush (Done by Sears)
    3.) Left Wheel Bearing (This was to remedy the issue of my ABS acting up. Remedy was a success)
    4.) Replaced 02 sensors
    5.) Replaced catalytic converter
    What the "pros" think it is:
    1.) BOTH CV Shafts.
    2.) Wheel Bearings (CV Shaft Slipping)
    2004 Pontiac Grand Prix GTP
    3.8L SC
    Presque Isle, ME
    "So far she tops at 130mph"
  2. #2 Re: 2004 Grand Prix GTP (SC)---Diagnosis help.
    HUDSON
    Question #4 can be caused by low transmission fluid.
  3. #3 Re: 2004 Grand Prix GTP (SC)---Diagnosis help.
    SE Level Member Gpmadness08's Avatar
    Sep 2013
    Peoria IL
    #3 idle air control valve might b defective
    ~ : Andrea : ~
    2008 GP @>~~\~~~
    Aka Charlotte
  4. #4 Re: 2004 Grand Prix GTP (SC)---Diagnosis help.
    Aug 2011
    'Merica
    I would also clean you TB and you MAF.
  5. #5 Re: 2004 Grand Prix GTP (SC)---Diagnosis help.
    Apr 2013
    Presque Isle, ME
    The fluid is perfect. all fluids are, actually. Ill check the sensors you guys have mentioned and report back. So, what are the chances it could be a CV Shaft?
    3.8L SC
    Presque Isle, ME
  6. #6 Re: 2004 Grand Prix GTP (SC)---Diagnosis help.
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    any access to a good scanner, (watch misfire count)
    Don't look for a IAC valve. Its drive by wire which is why joe said to clean your TB
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  7. #7 Re: 2004 Grand Prix GTP (SC)---Diagnosis help.
    Apr 2013
    Presque Isle, ME
    Just one more thing to add to this anomaly.... Not throwing a single code. I haven't had time to get those things checked yet, can i clean any of that stuff myself? I'll be flat out, i know just about nothing when it comes to the engine of a car, but if you ask me about installing lighting, sound and other equipment, i can do that with my eyes closed. haha. Its a alittle backwards i know
    3.8L SC
    Presque Isle, ME
  8. #8 Re: 2004 Grand Prix GTP (SC)---Diagnosis help.
    Jan 2013
    Edmonton, Alberta
    have you heard of goggle or utube.......
    Type in "How to clean a 3800 throttle body"
  1. 2004 grand prix gtp
    By TMBT1989 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2013, 04:38 PM
  2. 2004 pontiac grand grand prix gtp
    By jeffreytatro606 in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 06:23 PM
  3. 2004 Grand Prix GTP ( PLEASE HELP)
    By JeanBean in forum Introductions/Noob Questions
    Last Post: 08-27-2010, 09:27 PM
  4. 2004 Grand Prix GTP
    By NewGPkid in forum Introductions/Noob Questions
    Last Post: 08-25-2010, 09:13 PM
  5. 2004 Grand Prix HUD
    By l3enner in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2009, 03:04 PM
