Thread: 99 Grand Prix 3.8 non supercharge squealing noise under hood
Results 1 to 12 of 12
  1. #1 99 Grand Prix 3.8 non supercharge squealing noise under hood
    Aug 2013
    Modesto, ca
    I'm getting squealing noise, can not find the source. Appears to be stronger on the passenger side, replace belt an noise continues. It starts after 5 of driving and sometimes goes away with stop and go. I'm using stethoscope, but no luck, need advise...
  2. #2 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    When it does make the noise, see if you can't quick spray various pullies with WD-40 to try and find the one making the noise.
  3. #3 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    Aug 2013
    Modesto, ca
    I did it - no luck; the noise continued...
  4. #4 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    No noise with belts off?
  5. #5 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    it might be the ac compressor, it makes a squealing noise if its hung up
    99 Silver Gtp here --------------------> http://www.grandprixforums.net/my-99...gtp-80323.html
    slp headers ,straight pipe, intriuge suspension, cai, ported tb, performance roller lifters, and bulit trans. 04+ seats in and le spoiler on
  6. #6 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    I know when my power steering pump took a dump the pulley snapped and was still spinning inside causing a squeal it was a loud squeal too, I couldn't figure out what it was since I didn't have power steering anyways until the belt and pulley came off together on i95 ... Good times
  7. #7 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    Aug 2013
    Modesto, ca
    Quote Originally Posted by Bills1997GTP View Post
    Took belt off and noise continues. Is a dry noise like something is not lubricated, not metal to metal noise. My mechanic friend believes that noise is coming between engine and transmission; does any one know if it this vehicle has oil pump drive?
  8. #8 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    No oil pump drive.
  9. #9 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    Quote Originally Posted by Josejimenez View Post
    the trans pump is on the driver side and would be heard between the engine and tranny. they tend to whine when they go bad or have a clogged filter.
  10. #10 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    Aug 2013
    Modesto, ca
    Is there another name for tran oil pump?
  11. #11 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    Aug 2013
    Modesto, ca
    Sorry transfer pump?
  12. #12 Re: 99 Grand Prix 3.8 non supercharge squealing noise under hood
    Aug 2013
    Modesto, ca
    Correction, another name for trans pump?
  1. 1998 Grand Prix noise under the hood
    By Akcalvinkid in forum General Tech Discussion
    Last Post: 04-23-2013, 03:37 PM
  2. gerbile like noise/ squealing when i turn heater on
    By GrandPrixGt2001 in forum General Grand Prix Discussion
    Last Post: 10-29-2012, 06:44 PM
  3. Squealing noise when turning on A/C
    By jho786 in forum General Tech Discussion
    Last Post: 08-31-2011, 03:03 PM
  4. squealing noise
    By Mr Biegz in forum Off Topic Discussion
    Last Post: 11-20-2010, 08:02 PM
  5. Squealing Noise
    By eXceL(FAM) in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 07:49 PM
