Thread: Vibrations, Hard shifting, and loose feeling
Results 1 to 5 of 5
  1. #1 Vibrations, Hard shifting, and loose feeling
    Jul 2013
    Holly, MI
    I have a 2007 GP (base model) I purchased used in September of 2012 with around 127,000 miles on it. To date I have a little over 140,000. When I first purchased the vehicle, there were absolutely no issues with driving that I noticed and I am very sensitive to how cars handle due to my POS '05 Grand Am that turned into a money pit. Before purchasing the GP I had a local shop check it all out and all that was noted was a slightly loose outer passenger tie-rod that I negotiated into the price. After a week or so I brought the car to Belletire and had the tie rod replaced. After that I can't recall any difference in handling, which is good. Skipping a few months of good handling I had a few minor things here and there done like plugs/wires replaced just as a tune-up. I also decided to do a few routine GM recommended maintenances, such as Fuel System cleaning (helped with somewhat rough idle), Coolant flush, and lastly a Tranny flush (worst idea ever). Not too long after I started to get this harsh shifting which was later diagnosed as the popular P1811 code common in the 4T65E trannys. I've had it back to the dealer twice now because they told me a flush wouldn't harm in anyway and all they do is clear the code which allows the vehicle to shift smoothly for a couple days. Another issue along with the hard shifting I have noticed is this really annoying vibration. I have done quite a few things to the vehicle to try and get rid of the vibration, and nothing really seems to work. The vibration is felt in the seats as well as the steering wheel and seems to get a little bit worse upon acceleration. If I grip the steering wheel at the time and drive down a road going 50-60MPH, my hand moves left to right a little. This is where I need some input.
    Between 127,000 and my current 140k or so miles... I have replaced the following:
    Economy tires with somewhat upgraded Toyo brand tires (helped a little with vibration as well as overall handling)
    OEM Pontiac rims with an aftermarket set + new lugs and some new studs that needed replacing (Drag brand)
    All 4 rotors and pads (also fixed 2 stuck calipers)
    Both front wheel bearings
    Multiple alignments
    FOUR HUNDRED MILLION ROAD-FORCED BALANCES (hub-centric and all those little cute ways of doing it)
    All 4 mounts/struts
    Several inner/outer tie-rods (as of the other day they are all tight now)
    Intermediate Steering Shaft
    I have had this vehicle into SEVERAL shops and no one can figure it out, or I replace what they tell me and it doesn't affect driving at all.. I've spent hours online reading tons of different forums and have tried taking it places to try all the little tricks and still nothing. The hard shifting is a PCS issue so I'm not worried about it, it's more the vibration. The following have been checked and said to be in perfect working order according to several shops:
    Both half-shafts (cv-axles) and joints
    Several other different suspension components
    tire pressure as well as balance and alignment
    motor mounts (they are deteriorating a little, but have had them checked by multiple mechanics that say they are perfectly fine)
    I am starting to lose sleep over this, like no really I should be in bed rn. So if anyone could please give any input I would greatly appreciate it. I understand a car with this many miles is going to have things wrong with it but I have driven 2 GP's with over 160,000 miles and they drove 10x smoother than mine and I have replaced over half of the car.
  2. #2 Re: Vibrations, Hard shifting, and loose feeling
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Dang. That's weird! I can't believe no one could diagnose the problem!
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: Vibrations, Hard shifting, and loose feeling
    I live here. DirtDog's Avatar
    Jun 2012
    lmfao broskee. that wobble at 50-60 mph deal is exactly what ive been trying to diagnose hahahahaha
    on this page is where we start trying to figure mine out
    http://www.grandprixforums.net/her-n...-31-72403.html
    and yes i used to loose sleep over it...but now i just dont give a fu*k about it and have moved on to bigger and better things like a sunroof leak
  4. #4 Re: Vibrations, Hard shifting, and loose feeling
    If all that didn't help the vibration, it might be a CV axle. Thing there is, if the boot isn't ripped...no one might be thinking along those lines. It's a might. Some vibrations etc are tough to track down. Also check your mounts and the ones holding your engine at the top. Some of those bushings wearing out would transmit more vibration. While the mechanic is looking under the car..that mount is up top.
    On the 1811, have a transgo shift kit installed into the accumulator. The flush didn't hurt the trans, it only helped show a common issue.
  5. #5 Re: Vibrations, Hard shifting, and loose feeling
    SE Level Member holyghost's Avatar
    May 2013
    Cincinnati OH
    I would agree with bill, the only thing I can think of left that might cause your vibrations is possibly an axle shaft. Now to the naked eye they may look strait and the boots may not be torn but one shaft may be bent just a little or one of the bearings in the cv joint itself may be bad and causing your issue. Especially since it is only at certain speeds and such.
  1. Loose feeling in steering wheel?
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 06-16-2013, 07:37 PM
  2. Odd feeling shifting out of park etc
    By Travisgt2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-09-2013, 10:29 AM
  3. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  4. Shifting hard
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 08:25 PM
  5. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
