Thread: White/black/brownish gunk in radiator
Results 1 to 13 of 13
  1. #1 White/black/brownish gunk in radiator
    Jun 2013
    Michigan
    Hi there, noob here don't know if anyone had this problem couldn't find anything on the search engine but I just got my first Grand Prix GT 2001 3800, noticed it was over heating so I let it cool down and checked the coolant and found some white/black/brownish guu under the cap? Never seen this before. Couple days after the the white part starting turning into a brownish color. I poured in some Prestone antifreeze and filled it up but after running around for few hours, and letting it cool down checked it again, it needed more so guessing there's a leak somewhere too? And the "coolant low" light always stays on? The car has about 175,000 miles on it. Could really use some help here. Thanks.
  2. #2 Re: White/black/brownish gunk in radiator
    Dec 2012
    Where 4T65E's were born
    That gunk would be the result of someone mixing Dex-cool, and regular green coolant. They are not compatible.
    Look like this?
    If the low coolant light is on no matter how full the system is, it is bad and needs to be replaced. Could be gummed up.
    Check the engine oil dipstick and make sure there is no coolant in the oil (No foamy oil). You will probably need new LIM gaskets.
    Sold.
  3. #3 Re: White/black/brownish gunk in radiator
    I good guess is that the LIM (lower intake) gaskets are going out and its been eating the coolant slowly. The black/brown crap under the cap is likely the dex-cool coolant that has see air, dex-cool and air don't mix and thus it sludges up.
    If it was my car, I would do the intake gaskets, flush the coolant, new thermostat and run green coolant when done.
    There are a few write up's on this and even a video on how to do the job.
  4. #4 Re: White/black/brownish gunk in radiator
    Jun 2013
    Michigan
  5. #5 Re: White/black/brownish gunk in radiator
    Jun 2013
    Michigan
    It looks like this but it used to be worse it was completely covered in that foam like substance.
  6. #6 Re: White/black/brownish gunk in radiator
    Feb 2013
    37.295091, -121.930053
    big time flush for you five is right tho your going ot need a flush badly
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: White/black/brownish gunk in radiator
    Jun 2013
    Michigan
  8. #8 Re: White/black/brownish gunk in radiator
    Jun 2013
    Michigan
    Ok then I have another question, I added some Prestone antifreeze yesterday, and this morning I ran it to the gas station which is like a quarter of a mile away, when I came back out it was all over the floor, open the hood and it looked like it squeezed its way out of the top of the water pump, now would that be a gasket problem or the actual water pump?
  9. #9 Re: White/black/brownish gunk in radiator
    Feb 2013
    soulds like your gasket failed on ya but if your going ot do that might as well replace it with your flush.
  10. #10 Re: White/black/brownish gunk in radiator
    Jun 2013
    Michigan
    Alright then I'm gonna head out and get that. Ill let you know how it goes, thanks for the help.
  11. #11 Re: White/black/brownish gunk in radiator
    Feb 2013
    make sure you tourqe it down tho last thing you want is for it to blow up in your face with scolding hot coolant. thats no fun trust me on that
  12. #12 Re: White/black/brownish gunk in radiator
    Quote Originally Posted by Meliquin00 View Post
    sounds like the coolant elbow blew out, it the plastic part from the lim to alt bracket.
    you need to flush and clean your system out real good, flush it to clean water, then put some Prestone radiator cleaner stuff in, run it like that for a while, ( a nice little ride) then flush it again, and then add green coolant.
  13. #13 Re: White/black/brownish gunk in radiator
    Jun 2013
    Michigan
    Ok I'll do that. Thanks
  1. coolant low & gunk under radiator cap 2005 GT
    By mntnbiker in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2013, 09:21 AM
  2. Black or White??
    By Discchaser in forum Visual/Body Modifications
    Last Post: 03-01-2013, 10:19 PM
  3. Black or White?
    By csssaint12 in forum Visual/Body Modifications
    Last Post: 06-04-2012, 10:41 AM
  4. Found white gloop in my radiator
    By BigBadjohn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2011, 02:02 AM
  5. Gunk in Radiator
    By mmcfearin in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-15-2008, 07:43 PM
