Thread: Knock Retard
Results 1 to 6 of 6
  1. #1 Knock Retard
    SE Level Member Pontiac Grand Prix GT's Avatar
    Jun 2013
    Frenchburg,KY
    Once I detect knock retard how do I get rid of it? Thanks guys!!
  2. #2 Re: Knock Retard
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Depends on what kinda setup you're running. Old mounts, parts hitting against eachother can cause false KR. Usually headers is a good way to kill some KR. Or an IC. Pulley up and stay out of boost.
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  3. #3 Re: Knock Retard
    Feb 2009
    flintnasty MI
    you could try setting a trap and releasing it back into the wild. Maybe try spraying some knock repellant around your rocker panels.
  4. #4 Re: Knock Retard
    Cambridge, Ontario Canada
    KR won't hide there in most cases because of the rust... Try confusing the retard with intelligence - they usually run away at that point.
    2005 E55 - stock
  5. #5 Re: Knock Retard
    I live here. TLSheff's Avatar
    I've always been told you can take a solid blunt object, such as a Baseball Bat, or Tire Iron, etc... and hit the retard on the back of the head. Upon knocking the retard unconscious you can simply drag them into a cage and keep them away from the motor as to not cause more problems.
    I myself have not tried this, as I keep my retard under control and chained in place, but whatever works for you.
    Try some research and see what others have done to solve their retarded problems.
  6. #6 Re: Knock Retard
  1. Knock Retard
    By GTPJIM in forum Introductions/Noob Questions
    Last Post: 12-27-2012, 09:26 AM
  2. seeing some knock retard
    By blakgtp in forum General Tech Discussion
    Last Post: 11-05-2012, 11:02 AM
  3. New Knock Retard
    By Bluemagic in forum General Tech Discussion
    Last Post: 09-19-2012, 09:22 AM
  4. Knock retard on a NA
    By Ophidia in forum General Tech Discussion
    Last Post: 02-22-2012, 11:10 PM
  5. Knock Retard
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 01:05 AM
