Thread: HELLO I AM NEW FROM INDY AND I Need Some Help...
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    I have a 02 Grand Prix and my sway bar is broken....can I take it off until I buy another one? Is this safe? What will happen....
  2. #2 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    antioch ill
    front or rear? just dont plan on autocrossing it and you will be fine
  3. #3 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    I havent had a front sway bar for 2 years.
  4. #4 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Grand Rapids, MI
    youll be just fine with it off in the meantime. replace it with a dorman sway, it's solid metal vs the hollow ones that come stock. Dorman 927-100
  5. #5 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    antioch ill
    dorman front and gmpp rear sway best available
  6. #6 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Also do sway bar support the axle
  7. #7 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    antioch ill
    nope you dont actually need sway bars
  8. #8 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Its the front sway....
  9. #9 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Thanks Brandon
  10. #10 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Thanks
  11. #11 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Thanks....and I will....
    Also do you know the price range
  12. #12 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    leave it in there broken till you buy a new one, then swap it. if its making noise take the end link off and remove the broken loop on the bar if its not already broken off.
    it helps some to lower the rear sub frame 2 inches or so to clear the brake lines on the driver side where the cap bolts are.
  13. #13 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Front
  14. #14 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    antioch ill
    i paid 63 shipped on ebay for my dorman
  15. #15 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    dorman bars run 100 ish, depends on where you buy it. also get some polly bushing for the mounts, the dorman kit comes with new bushings but they really do suck, mine are year old and they need to be replaced, both sides are torn up and clunking. the end links seem to hold up ok so far.
  16. #16 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    One end broke off on driver side and the other end screw broke and now making grinding noise
  17. #17 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    antioch ill
    idk where to find poly bushing big enough for the dorman sway
  18. #18 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Can Dorman be found on internet or any auto parts store
  19. #19 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    antioch ill
  20. #20 Re: HELLO I AM NEW FROM INDY AND I Need Some Help...
    Jun 2013
    Indiana
    Its rattling very bad since passenger side broke
  1. New in Indy with GP #4
    By SteelBiker in forum Introductions/Noob Questions
    Last Post: 12-09-2011, 08:15 PM
  2. Hello from Indy!
    By lilwillgp in forum Introductions/Noob Questions
    Last Post: 09-18-2010, 09:00 PM
  3. Hi From Indy
    By hannon in forum Introductions/Noob Questions
    Last Post: 06-03-2010, 11:36 PM
  4. New guy from Indy
    By e3mcgrath in forum Introductions/Noob Questions
    Last Post: 07-17-2009, 08:03 PM
  5. New from Indy
    By bct717 in forum Introductions/Noob Questions
    Last Post: 03-14-2009, 11:50 AM
