Thread: questions??????
Results 1 to 10 of 10
  1. #1 questions??????
    May 2013
    kasson mn
    new to this site but I have a 94 gtp 3.4 dohc...running really rough did plugs still runs the same good fuel pressure new pump and filter feels like it has no power and "kicks" in and out of the miss will run fine for a few seconds till I touch the gas pedal...head gaskets and intake are fine....help please
    92 z34 3.4 dohc r.i.p...89 cutlass supreme international 2.8 mpfi 5 speed r.i.p
  2. #2 Re: questions??????
    Try unplugging the MAF sensor?
    Maybe a large vacuum leak aswell.
  3. #3 Re: questions??????
    There is a vacuum line that runs under the intake manifold it dry rots a lot and causes a large vacuum leak, the car will idle funny, it doesnt seem to have much power, you might get some backfiring.
  4. #4 Re: questions??????
    May 2013
    kasson mn
    is it usually green with a 2 prong wire?
  5. #5 Re: questions??????
    May 2013
    kasson mn
    can you acess the vaccum line with out taking the intake off?
  6. #6 Re: questions??????
    The mass air flow is the thing in the intake tube, let me see if I can find a picture of it.
    No you have to take the upper intake off.
  7. #7 Re: questions??????
    The MAF looks very similar to this, its on the intake tubing.
    http://treperformance.com/images/F17909673.jpg
  8. #8 Re: questions??????
    Its on this thing in the intake tube.
  9. #9 Re: questions??????
    May 2013
    kasson mn
    Just replaced that, found a vacuum line that runs from valve cover to valve cover that was disconnected would that cause the problem?
  10. #10 Re: questions??????
    It might, the 3.4 is really picky with vacuum leaks.
  1. KR Questions...
    By Jackblack99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2012, 11:01 AM
  2. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  3. some questions
    By NewGPkid in forum General Tech Discussion
    Last Post: 10-04-2010, 08:39 PM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. some questions from a new guy
    By buster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 02:25 PM
