Thread: Air is rushing out from gas tank.
Results 1 to 9 of 9
  1. #1 Air is rushing out from gas tank.
    May 2013
    Fresno Ca
    I have a 2007 grand prix, it's been running rough.code came up PO455 so I change the gas cap, then the purge solenoid. It ran good for a while the the engine light came back on. Can it be the charcoal canister are what? I read there is a blender valve for the canister but I don't know where it is.... Please help I'm wasting to much gas
  2. #2 Re: Air is rushing out from gas tank.
    What does 455 stand for?
  3. #3 Re: Air is rushing out from gas tank.
    May 2013
    Fresno Ca
    Evap
  4. #4 Re: Air is rushing out from gas tank.
    Feb 2013
    37.295091, -121.930053
    455 is a Pontiac engine that came in 3 flavors your 455, 455 h.o., and 455 sd. The h.o. and sd ones make 500 hp on a 750cfm quadrajet.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Air is rushing out from gas tank.
    you changed everything but what you should have changed it seems.
    OBD-II Trouble Code: P0455 Evaporative Emission Control System Leak Detected (no purge flow or large leak)
    What does that mean?
    This indicates a fuel vapor leak or lack of purge flow in the EVAP control system. It means a large leak has been detected. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
  6. #6 Re: Air is rushing out from gas tank.
    May 2013
    Fresno Ca
    So what do I do.. Check gas lines. How do I check the charcoal canister
  7. #7 Re: Air is rushing out from gas tank.
    id be changing the canister and the sensor thats in it, its located in the driver side rear wheel well. its the last part to a whole new evap system, being you changed all the other parts already.
  8. #8 Re: Air is rushing out from gas tank.
    May 2013
    Fresno Ca
    Yea thts Wht I thought but wasn't sure. Do I have 2 droop the tank are just unplug the hoses and take off the canister.
  9. #9 Re: Air is rushing out from gas tank.
    take the tire off, and the plastic wheel well line, unhook the lines and the plug, unbolt it.
    theres how to's out there, google works best.
    looks like this.
  1. fuel tank
    By 99grandgt in forum General Grand Prix Discussion
    Last Post: 07-27-2012, 07:44 PM
  2. Air Rushing sound after headers install
    By DoubleBlown in forum General Tech Discussion
    Last Post: 05-21-2012, 06:21 PM
  3. Gas Tank?
    By BlackSun in forum General Tech Discussion
    Last Post: 11-18-2010, 01:45 PM
  4. gas tank?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 05-11-2009, 06:19 PM
  5. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
