Thread: Need help with problems
Results 1 to 17 of 17
  1. #1 Need help with problems
    Apr 2013
    Canada
    Hey guys I looking to buy a 98 gtp fully loaded with 160kms for around $2500. At a glance it seems like a good deal to me but i took it for a test drive and it seems to have a few issues. 1) the brakes need to be replaced because they are ****. 2) it has a custom exhaust that sounds like it has a leak. and 3) the engine shakes the entire car. So i'm not so worried about number 1 and 2 so much but number 3 has me worried. I inspected the car pretty decently and the engine shakes and kind of makes a knocking sound that seems to be coming from the supercharger. ANY opinions or analysis would be appreciated! thanks guys
  2. #2 Re: Need help with problems
    Banned
    Jan 2013
    Colorado
    I would check the engine mounts.
  3. #3 Re: Need help with problems
    Apr 2013
    Canada
    That's what I was thinking, but there is still a slight knocking sound in the supercharger area
  4. #4 Re: Need help with problems
    sc coupler easy fix.
  5. #5 Re: Need help with problems
    Apr 2013
    Canada
    please expand! haha i'm really hoping it's nothing major
  6. #6 Re: Need help with problems
    The snout of the blower has to come off there is a plastic coupler in there and it gets worn out and need replacing every now and again.
  7. #7 Re: Need help with problems
    Does it sound like it has rocks in it?
  8. #8 Re: Need help with problems
    Apr 2013
    Canada
    yup you guys nailed it i think. so i got bad brakes, possible exhaust leak, and this coupler. how much do you guys think all this would cost me?
  9. #9 Re: Need help with problems
    Coupler and supercharger fluid shoudl be about $40 tops and the brakes and exhaust leak it really just depends.
  10. #10 Re: Need help with problems
    Doing the brakes and sc coupler yourself probably about $100. Exhaust will vary. I had a turbo back put on my passat for $150 at a local exhaust shop.
  11. #11 Re: Need help with problems
    Apr 2013
    Canada
    my brother seems to think that the engine shaking at idle could be a bad cylinder. what do you think?
  12. #12 Re: Need help with problems
    See which codes it's throwing
  13. #13 Re: Need help with problems
    It could be a bad motor mount.
  14. #14 Re: Need help with problems
    Apr 2013
    Canada
    Well hopefully the guy wont mind me taking it to a parts store to check codes but if there arent any codes does that rule out the cylinder?
  15. #15 Re: Need help with problems
    You'd have to do a compression test to be positive
  16. #16 Re: Need help with problems
    It could need a tune up pretty badly too. and it might be a chipped piston. Although they usually idle pretty good with a chip.
  17. #17 Re: Need help with problems
    Apr 2013
    Canada
    thanks guys but i think i'm just going to pass on this one.
  1. Two Problems
    By tommymcd in forum General Tech Discussion
    Last Post: 02-15-2011, 12:39 AM
  2. problems! help!
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2011, 12:15 AM
  3. I've got problems...
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2010, 06:48 PM
  4. Still having problems
    By fudhimself in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 08:26 PM
  5. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
