Thread: abs light
Results 1 to 4 of 4
  1. #1 abs light
    SE Level Member GTByron's Avatar
    Mar 2013
    Florida
    Noticed that my abs&trac light will come on if I hit a bump on the driver side front tire. It doesn't always come on when I hit a bump but it does it sometimes...any suggestions?
  2. #2 Re: abs light
    Nov 2011
    NY
    Loose connection/wire...
  3. #3 Re: abs light
    SWPA
    Wires are probably frayed/broken. Had the same issue last year.
  4. #4 Re: abs light
    like these guys said, or a bad hub, just had to change one myself, if i was turning and if i hit a bump the light would turn on.
    jack up each wheel, lugs tight, see if you can feel any movement out of the front hubs, is so the hub is bad.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
