Thread: Exhaust for both gtp and Gxp need help :)
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    Alright I have been tossing up a idea with marines about doing a custom true duel exhaust okay aleast the almost true duals lol, maybe going public with it and the other problem I have right now is I need undercarriages of both body styles. But I need thoughts ideas and who would actually buy a kit!
    It is just a FAMILY CAR
  2. #2 Re: Exhaust for both gtp and Gxp need help :)
    I live here. DirtDog's Avatar
    Jun 2012
    People have dome it before with the 3.8 btw. Just don't remember what all they did. I'll find links as to where they did it later
  3. #3 Re: Exhaust for both gtp and Gxp need help :)
    Jun 2012
    If it can be done for the gxp it would be awesome. The trick is making it work. I'm thinking right now and if these cal speed headers get released then money wise a 3 inch single pipe would end up probably being cheaper
  4. #4 Re: Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    . The #5 is the one I'm looking at doing, where the little hash marks are that's where it would disconnect and reconnect, would have to use a long tube muffle vs like a flow master 44
    and marine yes with the headers it would be better but for the people not wanting to spend money on headers due to pain in the ass install and the price, this could be a good alternative and would flow pretty nice!!!
    And the price would be what it cost to build and ship, not trying to get rich just trying to help myself and my fellow gxpers out
    and if you wanted cutouts still it would be cost of build plus the cutouts and shipping, and you would have the option of bolt on or weld in yourself
  5. #5 Re: Exhaust for both gtp and Gxp need help :)
    Jun 2012
    Interesting. If u can make it happen and all id be all over a set. Itd be perfect with headers
  6. #6 Re: Exhaust for both gtp and Gxp need help :)
    Looks like you have it coming from the engine into one pipe then back out into 2. How is this much different then stock?
  7. #7 Re: Exhaust for both gtp and Gxp need help :)
    Jun 2012
    I think what he was saying is off the headers the two pipes would be close together coming down where the DP is the open back up some
  8. #8 Re: Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    Also looking at maybe a 3inch catback system
  9. #9 Re: Exhaust for both gtp and Gxp need help :)
    Jun 2012
    Wait so ur saying both the exhaust manifolds would still connect together right behind the engine
  10. #10 Re: Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    It would come off the manifolds at a v which out transform it into duel right there then continue the duel exhaust all the way to the back the only single part would be at the manifold where it connects
  11. #11 Re: Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    Quote Originally Posted by marines542 View Post
    Yes unless I can go ahead and build a cross over pipe that would make it a true true duel exhaust
  12. #12 Re: Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    The only reason why I would like to do the one where they still meet at the back of the motor is because if I did build a true true kit the left exhaust would have a totally different note then the right due to the extended amount of pipe to go, the cross over part then where the exhaust splits ways in the rear of the car it would create a huge differnece in exhaust notes!!!
  13. #13 Re: Exhaust for both gtp and Gxp need help :)
    Jun 2012
    True dual means the exhaust from each side of headers doesn't meet. If that makes since.
    Completely desperate from each other. That area may be why no one does it for the ls4 cause it'd be hard
  14. #14 Re: Exhaust for both gtp and Gxp need help :)
    Donating User Odi's Avatar
    Chicago South Suburbs
    one thing in this thread really bothers me... DUAL not duel.
  15. #15 Re: Exhaust for both gtp and Gxp need help :)
    Jun 2012
    Its magic. All the posts edited their selves
  16. #16 Re: Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    Sorry dual, and in the ordinal post I said okay almost true dual lol, I could build a kit to do a true dual but the exhaust tone would be stupidly different like I stated above lol
  17. #17 Re: Exhaust for both gtp and Gxp need help :)
    SWPA
    There is zero point in seperating the pipes so far forward. You aren't going to gain anything but weight. Stick with a single pipe back to before the rear axle then go into a single in dual out muffler.
  18. #18 Re: Exhaust for both gtp and Gxp need help :)
    Oct 2012
    Nowhere NY
    There is zero point in departing the pipes so far forward. You aren't going to gain anything but weight. Stick with a single pipe back to before the rear axle then go into a single in dual out muffler.
    Agreed, for the amount of work it will take, in IMHO i dont think its worth it
    Ive been medicating with burnouts and alcohol
  19. #19 Re: Exhaust for both gtp and Gxp need help :)
    Jun 2012
    U could make a good bolt on minderail (I can't spell) bent 3 inch cat back!!!!!! Id buy just cause I aitn buying magna flows. And u could have it to where people then get their own mufflers and or tips
  20. #20 Re: Exhaust for both gtp and Gxp need help :)
    Dec 2012
    wichita,ks
    Which is also why we did the 3 inch catback kit idea to, the dual was just a far out thought lol, and that's why I wanted your opions lol. How ever you spell it
  1. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum General Tech Discussion
    Last Post: 03-18-2009, 02:47 AM
