Thread: Help what is this plug in!?
Results 1 to 20 of 23
Kcgp Help what is this plug in!? 04-25-2013, 07:07 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 07:11 PM
Kcgp Re: Help what is this plug... 04-25-2013, 07:17 PM
Kcgp Re: Help what is this plug... 04-25-2013, 07:16 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 07:24 PM
Kcgp Re: Help what is this plug... 04-25-2013, 07:29 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 07:37 PM
Kcgp Re: Help what is this plug... 04-25-2013, 07:49 PM
Kcgp Re: Help what is this plug... 04-25-2013, 07:52 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 08:02 PM
Kcgp Re: Help what is this plug... 04-25-2013, 07:43 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 07:48 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 07:57 PM
Kcgp Re: Help what is this plug... 04-25-2013, 07:59 PM
Kcgp Re: Help what is this plug... 04-25-2013, 08:05 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 08:09 PM
Kcgp Re: Help what is this plug... 04-25-2013, 08:11 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 08:14 PM
Kcgp Re: Help what is this plug... 04-25-2013, 08:15 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 08:28 PM
Kcgp Re: Help what is this plug... 04-25-2013, 09:36 PM
Scottydoggs Re: Help what is this plug... 04-25-2013, 09:44 PM
BillBoost37 Re: Help what is this plug... 04-26-2013, 06:21 AM
  1. #1 Help what is this plug in!?
    Jan 2013
    Kansas city
    what is this plug in? It's right behind my front left tire. It came unplugged on day and was just hanging from the bottom. Could that be why my abs light is on? Could could it cause problems?
  2. #2 Re: Help what is this plug in!?
    if the abs light went off after you plugged it in, you fixed your problem.
  3. #3 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    Do I have to reset the system?
  4. #4 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    No the abs light is still on
  5. #5 Re: Help what is this plug in!?
    no resetting for abs, or air bags, when whats broke is fixed its a instant fix, aka light goes off.
    you need to check all your hubs are plugged in, take them off clean them, add a dab of di electrical grease to the ends, work that in. also check the harness that runs along the lower control arms, they get torn up some times.
    you can check each hub for play by jacking the car up, leave the wheel lugs tight, then push and then pull the top of the tire, if you feel play the hub is bad.
    check all 4 wheels, if all feel tight, have the car scanned at a shop for abs codes, they can pin point the problem. better then you tossing money at it.
    hubs cost about 130 each for a good name brand. dont get the parts store brand, they dont last so long, and have a short warranty.
  6. #6 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    Alright thanks I'll get right on that but is that the abs connecting that blue plug in in the picture. What is it for if not?
  7. #7 Re: Help what is this plug in!?
    just looked at it again, hows your steering? could be the mangna steer plug from the rack and pinion. follow the side thats going to towards the engine. if it leads to the fat part of the rack where the steering column bolts in, thats it.
    found a pic, blue plug on the rack wire.
  8. #8 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    I think the wire just Leds to a bunch of wires in a big tube
  9. #9 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    Alright thanks for all the help man! One last question when that wire was unplugged would it even make a difference?
  10. #10 Re: Help what is this plug in!?
    looks like the rack wire from this pic, its from a how to i just found.
  11. #11 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    I mean it's fine just some popping noises but not horrible.
  12. #12 Re: Help what is this plug in!?
    while your testing the hubs grab the fron tires at the 9 and 3 o clock positions, then push and pull the wheel side to side, if it moves, you need tie rods.
    take the wheels off, check the sway bar end links, and the sway bar end for cracks, and look at the rubber bushing in the sway bar cap on the frame, just follow the bar to it.
    also take a look at the bushings for the lower control arms you'll see the one clearly with the tire off, if its all torn up, you need a new pair of lca's. they are cheap at 42 bucks a side on line. its a whole new lca, comes with 2 new bushing and the ball joint.
  13. #13 Re: Help what is this plug in!?
    no idea, being we dont what its for yet. if you got a set of car ramps, or jack and stands, get under the car and see where it goes.
    im still kinda stuck on the rack plug. i know it plugs in off the side of the tranny there, but its been a while since i changed mine.
  14. #14 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    Haha alright I'll see what's going on under there this weekend thanks
  15. #15 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    Wait I don't even see it, I'm talking about the blue one
  16. #16 Re: Help what is this plug in!?
    its higher on the tranny in this pic. follow the black wire up to the tranny top.
  17. #17 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    I see it yeah now that I think about it it was on that other pic you put on. Solo would it effect driving?
  18. #18 Re: Help what is this plug in!?
    it would make your steering stiffer at slow speeds. ( unplugged) magna steer helps ease the steering at slow speeds, like for parking. it may turn easier now.
  19. #19 Re: Help what is this plug in!?
    Jan 2013
    Kansas city
    Ohhh alright wouldn't effect the abs light?
  20. #20 Re: Help what is this plug in!?
    ok bear with me on this part lol
    when the abs light does trip on some cars, it will make the steering stiff. like it cancels out the magna steer, some cars it does nothing to the steering.
    so being they are tied in together some how, it maybe could. but also being the light stayed on, im thinking its not the problem right now.
    back to the hubs and wires. as thats the single most common failure for a abs light to come on.
    when my hubs went bad, they were moving and tripping the abs light, and they made my brakes suck, they would fade and have a mushy pedal. some more insight to a bad hub for ya.
    my last hub, a week or so a go. sensor cap broke off stayed in the knuckle.
    new goodness.
  1. Plug gap
    By Gerryk in forum General Grand Prix Discussion
    Last Post: 12-16-2012, 07:12 PM
  2. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  3. DRL's plug
    By GP24 in forum Visual/Body Modifications
    Last Post: 05-23-2012, 11:57 AM
  4. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  5. Which plug for a 3.5?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 09:20 AM
