Thread: Clunking from passenger side tire area
Results 1 to 7 of 7
  1. #1 Clunking from passenger side tire area
    Apr 2013
    I have an 04 Grand Prix gt, it recently started making a clunking/ rattle when going over small bumps. It won't rattle when I'm turning, only going stright. I took the tire off and didn't find anything I thought was loose. Any ideas where to look would be Appreciated.
  2. #2 Re: Clunking from passenger side tire area
    open the hood and shake the car back and forth and look at your strut mounts.
  3. #3 Re: Clunking from passenger side tire area
    Apr 2013
    They don't move, I tried pushing down, still dont move, but also doesn't make the noise.
  4. #4 Re: Clunking from passenger side tire area
    Jan 2013
    michigan
    check you lca bushing
  5. #5 Re: Clunking from passenger side tire area
    Sway links are another common issue.
  6. #6 Re: Clunking from passenger side tire area
    Apr 2013
    I'm not sure what a LCA is?
  7. #7 Re: Clunking from passenger side tire area
    lower control arm
  1. oil leak on passenger side, 98 gt.
    By kind153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2014, 01:20 AM
  2. Help On Clunking Noise In Rear Side
    By xxquortneexx in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 09:46 PM
  3. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  4. Passenger Side Air Bag Replacement
    By Fixthis in forum General Tech Discussion
    Last Post: 01-25-2011, 06:22 PM
