Thread: Noob Question - Tire Sensors and After Market Wheels
Results 1 to 10 of 10
  1. #1 Noob Question - Tire Sensors and After Market Wheels
    SE Level Member Koopa's Avatar
    Apr 2013
    Memphis TN
    I haven't been on this forum for an hour yet and already have a question, lol!....Ok I seen a set of wheels I was interested in buying. Once I got to the end of the transaction process the asked about TPMS (tire pressure monitoring sensors)....My question is, do I have to have them...the site stated that they are optional, if I don't need them that's $199.96 in my pocket mwha ha haaa!
  2. #2 Re: Noob Question - Tire Sensors and After Market Wheels
    If would help if you told us what car you drive.
    We can't read minds.
  3. #3 Re: Noob Question - Tire Sensors and After Market Wheels
    Apr 2013
    Memphis TN
    lol im sorry I was having trouble uploading my signature I have an 05' Grand Prix GT
  4. #4 Re: Noob Question - Tire Sensors and After Market Wheels
    Do you have a TPMS?
    Even if you do, it's just a light that will stay on saying "check tire pressure".
  5. #5 Re: Noob Question - Tire Sensors and After Market Wheels
    More than likely your rims have rubber valve stems, so you shouldnt need them.
  6. #6 Re: Noob Question - Tire Sensors and After Market Wheels
    SWPA
    I would spend the money and get them. If not you are going to have a light on and a ding everytime you start the car.
    Other option would be to forgo them from wherever you are getting the rims, and have the tire shop break down your stockers and swap the factory sensors into the new wheels.
  7. #7 Re: Noob Question - Tire Sensors and After Market Wheels
    Being an 05 GT, I doubt they have sensors.
    But the OP still needs to check his rims for regular valve stems or plastic/metal sensor stems.
  8. #8 Re: Noob Question - Tire Sensors and After Market Wheels
    Dec 2012
    wichita,ks
    I have it? I'm also been asking myself the same
    It is just a FAMILY CAR
  9. #9 Re: Noob Question - Tire Sensors and After Market Wheels
    SE Level Member MillCityGTP's Avatar
    Apr 2013
    Lowell, MA
    Definetely check the valve stems like everyone else says. I doubt your car has tire pressure monitors. One other thing you could check is when you first start the car up, and all the lights on the cluster turn on to show they're working, look for a symbol of the bottom half of a tire with an exclamation point in the middle of it. That's usually what it looks like, I'm not one hundred percent sure. Some late model GM cars use what's called a passive tire pressure monitoring system. It uses the wheel speed sensors to detect small differences in wheel speed due to underinflation of the tires. Hope that helps.
    2003 Pontiac Grand Prix GTP Limited Edition
    ZZP MPS w/3.5" - 3" DP - Front and Rear ZZP Powerlogs - 4" Intake - 180* stat - 104's - GMPP Front and Rear STB's - ZZP Poly Mounts - ZZP Coils - Overkill Tuned - 17x7.5 Bonneville Lace Wheels
  10. #10 Re: Noob Question - Tire Sensors and After Market Wheels
    Dec 2012
    wichita,ks
    How can you delete it? When you change rims?
  1. are these tire pressure sensors one in the same / exact same
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:18 AM
