Thread: Need help with codes
Results 1 to 15 of 15
  1. #1 Need help with codes
    Apr 2013
    Canada
    hey guys check engine light came on. got the codes read. P1404 and P0742. anyone know what these are and how to fix?
  2. #2 Re: Need help with codes
    Apr 2013
    Canada
    p0404 sorry
  3. #3 Re: Need help with codes
    P0404 Exhaust Gas Recirculation Circuit Range/Performance - DTC Code
    OBD2-OBDII Engine Light Trouble Code P0742 CHEVROLET - Torque Converter Clutch Circuit Stuck On | Engine-Codes.com
    Took me all of 5 seconds to google both of those codes just fyi.
    Most likely scenario get a new egr valve and drop your trans pan change the filter and put in new fluid. You might need a new Torque Converter Clutch Solenoid.
  4. #4 Re: Need help with codes
    Apr 2013
    Canada
    the code reader said what was wrong but I just wanted advice on what to do about it. How hard is it to fix the egr?
  5. #5 Re: Need help with codes
    Nov 2011
    indiana
    not hard, what usually happens is a piece of carbon gets in there and prevents the plunger from full closing, what i've done in the past it take it off and clean it really good, and also wouldn't hurt to buy a screened egr gasket. its a gasket that has a screen to prevent large pieces of carbon build up from clogging it.
  6. #6 Re: Need help with codes
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Does the Forum have a list of all the codes? Would be great to come to the forum and check the list, instead of deciphering Google results.
  7. #7 Re: Need help with codes
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    where you at skippy?
    p0404 means your actual egr postion and the desired egr position are not equal, like slick said its most likley cabon deposits,
    p0742 torque converter clutch (tcc) system - stuck on. pcm detected that the tcc release switch is closed when the tcc is commanded off. mil will come on, and the pcm disables shift adapts and commands tcc on at maximum capacity
    harsh shift, tcc shudder on decel, tcc applied in 2nd gear and p0742 may be caused by faulty tcc pwm solenoid.
    rapid fluctuation in line pressure could set dtc, inspect for pressure regulator problem or abnormal line pressure.
    other problems, turbine shaft teflon sealing rings have come apart and damaged the turbine shaft and channel plate,
    internal PWM TCC soleniod o-ring out of postion or damaged.
    thats all my scanner says good luck,
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  8. #8 Re: Need help with codes
    Apr 2013
    Canada
    Im in regina, too bad haha. So your description says that the 0742 is likely a solenoid problem? Opinions here guys...what should i do: change the ATF or check out the solenoid?
  9. #9 Re: Need help with codes
    Mar 2013
    Manitoba, Canada
    Change the fluid. DON'T flush it, just drop the pan, drain fluid, change filter, install pan, refill with fluid. Can't remember the type of fluid you should use, hope someone else can chime in on that one, or just search the forum. It certainly won't hurt, is not expensive, and probably needs changing anyways.
  10. #10 Re: Need help with codes
    Jan 2013
    Edmonton, Alberta
    dexron 6 should work in all dex 3 applications,
    ive read its better in every way, Our Products — DEXRON®-VI
  11. #11 Re: Need help with codes
    Apr 2013
    Canada
    pssshhtt manitoban. you think that will solve my problem though? i deleted the codes and it hasnt come back. so im thinking you might be right about the dirty oil. the egr code came back though so i will fix that. any advice on the egr change?
  12. #12 Re: Need help with codes
    Jan 2013
    Edmonton, Alberta
    try the simple frist,
    but here you go other wise,
    remove the case side cover
    dissconnect Tcc solenoid connector
    remove retaining clip (314)
    remove solenoid (315)
    Install solenoid (315)
    install retaining clip (314)
    put on connector,
    put side cover on
    probly should erase transmission adapttive pressure info with a scanner
    Attachment 11432
  13. #13 Re: Need help with codes
    Apr 2013
    Canada
    thanks guy. advice on the egr?
  14. #14 Re: Need help with codes
    Jan 2013
    Edmonton, Alberta
    well, i would erase codes and see what happens,
    if it comes back, take off egr and try and clean as much carbon from it as possible
    erase code and see what happens,
    if it comes again just replace it
    Attachment 11433
  15. #15 Re: Need help with codes
    Apr 2013
    Canada
    you guys are good
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. PID Codes?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 10-20-2010, 07:41 PM
  3. Car Codes
    By 1996pontiac in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2010, 08:23 AM
  4. Codes for A/C
    By ASTROALCHER in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 12:49 PM
  5. GM RPO Codes
    By mkuhn20 in forum General Tech Discussion
    Last Post: 01-21-2009, 04:47 PM
