Thread: Need help with codes
Results 1 to 15 of 15
  1. #1 Re: Need help with codes
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    where you at skippy?
    p0404 means your actual egr postion and the desired egr position are not equal, like slick said its most likley cabon deposits,
    p0742 torque converter clutch (tcc) system - stuck on. pcm detected that the tcc release switch is closed when the tcc is commanded off. mil will come on, and the pcm disables shift adapts and commands tcc on at maximum capacity
    harsh shift, tcc shudder on decel, tcc applied in 2nd gear and p0742 may be caused by faulty tcc pwm solenoid.
    rapid fluctuation in line pressure could set dtc, inspect for pressure regulator problem or abnormal line pressure.
    other problems, turbine shaft teflon sealing rings have come apart and damaged the turbine shaft and channel plate,
    internal PWM TCC soleniod o-ring out of postion or damaged.
    thats all my scanner says good luck,
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. PID Codes?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 10-20-2010, 07:41 PM
  3. Car Codes
    By 1996pontiac in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2010, 08:23 AM
  4. Codes for A/C
    By ASTROALCHER in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 12:49 PM
  5. GM RPO Codes
    By mkuhn20 in forum General Tech Discussion
    Last Post: 01-21-2009, 04:47 PM
