Thread: Heads up Display is Dim
Results 1 to 6 of 6
2001GPGTP Heads up Display is Dim 04-10-2013, 05:56 PM
firstdue Re: Heads up Display is Dim 04-10-2013, 06:02 PM
2001GPGTP Re: Heads up Display is Dim 04-10-2013, 06:06 PM
BillBoost37 Re: Heads up Display is Dim 04-11-2013, 07:02 AM
loopy smurf Re: Heads up Display is Dim 04-11-2013, 09:09 AM
dsmuts Re: Heads up Display is Dim 04-11-2013, 04:00 PM
  1. #1 Heads up Display is Dim
    Mar 2013
    California
    Hey a quick ? My HUD recently started getting dim and after researching a little it could probably be needing to be resoldered? I'm not that handy so would this be a somewhat easy task to do ? Or should I just not mess with it ? Again it's getting dim during the day. Any suggestions are welcomed .
  2. #2 Re: Heads up Display is Dim
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Even if you don't have great soldering skills its not too bad. I did mine over a year ago and its still nice and bright. The solder points are pretty easy to hit with not much around them if I remember correctly. I had a harder time getting the dash pieces apart without breaking anything.
    Sent from my DROID RAZR using Tapatalk 2
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  3. #3 Re: Heads up Display is Dim
    Mar 2013
    California
    Ok thanks I'm still hesitant but might end up trying thanks!
  4. #4 Re: Heads up Display is Dim
    It's super easy. Once the iron is up to temp..all you have to do is touch the two locations for the piece. You touch one..and see the solder move a little.. move to the other and poof..done.
  5. #5 Re: Heads up Display is Dim
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    I need to do this as well - mine isn't just dim, it's typically out all together...then comes on for a bit, then fades out completely again. My main concern isn't the soldering part - it's taking the dash pieces out. Never done that on this car, and not sure how...
  6. #6 Re: Heads up Display is Dim
    I've done a couple. Brandon's using my old one now.
  1. Heads up display
    By Widetrackjohnny in forum General Grand Prix Discussion
    Last Post: 02-18-2013, 04:30 AM
  2. What's up with my Heads up display??
    By nawarkk in forum General Tech Discussion
    Last Post: 01-23-2010, 12:14 AM
  3. heads up display (hud)
    By Viperhunter in forum General Tech Discussion
    Last Post: 10-08-2009, 01:44 PM
  4. heads up display
    By dmoney01 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:36 PM
