Thread: Multiple eng codes and reduce eng power
Results 1 to 8 of 8
  1. #1 Re: Multiple eng codes and reduce eng power
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    have you checked wiring at app sensor connector, and between the throttle body connector
    edit, the app connetor has 6 wires on it, 3 for each sensor,
    for sensor 1
    wh-bk is 5v ref
    d-bu is signal
    bn is low ref
    sensor 2
    tn is 5v ref
    L-bl is signal
    pu is low ref
    for on the Tac module(throttle body) pins 1-3, 11-13 same colors
    i dont know if this is correct for a 05, as this is for 07
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. Multiple EGR Codes
    By rbob900 in forum General Grand Prix Discussion
    Last Post: 04-05-2013, 04:23 PM
  2. Multiple Codes!!!! Need Help!
    By roundbox52 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2010, 08:01 PM
  3. Multiple codes
    By silverstreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 12:35 AM
  4. reduce engine power / service traction system
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 06:56 PM
  5. reduce engine power warning
    By rochaedkj in forum General Tech Discussion
    Last Post: 07-12-2009, 06:24 PM
