Thread: 99 gtp questions/advice
Results 1 to 4 of 4
  1. #1 Re: 99 gtp questions/advice
    Take a good luck underneath at the rockers. They are known for rusting easily. Also take a look in the trunk at the strut towers. Those are the major rust areas.
    Run the car past your insurance carrier as to which is good for your son.
    On the mileage, the numbers you came up with are about right depending on driving style.
    Premium fuel or pistons chip when it's beat on. That's unfortunately all too common.
    Intake gaskets, when you look at the car, look for the updated metal gaskets by the thermostat housing where the intake manifold meets the head. If it's black..you will want to do it as preventative maintenance.
  2. #2 Re: 99 gtp questions/advice
    Apr 2013
    Ohio
    Thanks for the info. Keep it coming! I have looked around a little on the forum and see you guys are crazy for these cars. I know there's lots of knowledge out there!!
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. I need your advice
    By Lenny in forum Off Topic Discussion
    Last Post: 06-06-2011, 01:20 AM
  3. some quick advice/questions
    By jerZcavy4120 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 04:38 PM
  4. Hi, Looking for some advice.
    By Cliffy in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2010, 08:58 PM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
