Thread: Problems
Results 1 to 20 of 20
  1. #1 Problems
    GT Level Member GrandPriest24's Avatar
    Jan 2013
    Michigan
    On the front floor i hear a louder dragging groan vibrating noise wondering what it could be at all?
  2. #2 Re: Problems
    Sep 2011
    Copperas Cove, TEXAS
    Could be a bad wheel bearing or hub.
  3. #3 Re: Problems
    "could be at all"?
    Do you hear the noise moving, not moving, blower on, off?
  4. #4 Re: Problems
    Jan 2013
    Michigan
    I'll apply pressure to gas and let off and i hear a droning sound and vibration from the floor if that helps at all
  5. #5 Re: Problems
    Apr 2012
    Goderich, Ontario
    Droning sound could be a wheel bearing or mabe your loud exhaust. I've never had a wheel bearing vibrate on me though.
    -Paul Walker
  6. #6 Re: Problems
    GT Level Member Luckys03GTP's Avatar
    Mar 2013
    Concord NC
    im with smoke
  7. #7 Re: Problems
    Sep 2011
    forgot you got open exhaust now, yeah when you let off the exhaust makes a drone, my ride does it kinda too.
  8. #8 Re: Problems
    Jan 2013
    Michigan
    no when i turn right there is a grinding noise
  9. #9 Re: Problems
    Apr 2012
    Goderich, Ontario
    Don't turn right
    -Paul Walker
  10. #10 Re: Problems
    Jan 2013
    Michigan
    good one aha
  11. #11 Re: Problems
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    hard to help with such a poor description
    front,back,driver,pass,
    i wanna say cv but we need better info
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  12. #12 Re: Problems
    Jan 2013
    Michigan
    When im driving my car when i left off the gas i feel vibration through the floor in the front i feel the pedal floor and the shifter all vibrating it isn't the exhaust i know that because this just started up and when i turn left nothing happens but right i feel a grinding and hear it also on the floor it sounds from the wheels i can tell you that it just started up it acts up when i brake and turn right so if that is any better description for you please let me know
  13. #13 Re: Problems
    Jan 2013
    Michigan
    okay i'll explain it all
  14. #14 Re: Problems
    Jan 2013
    Edmonton, Alberta
    do u feel it through the steering wheel
  15. #15 Re: Problems
    Apr 2012
    Goderich, Ontario
    If it does this when your breaking then its a warped rotor and/or worn out pads.
    -Paul Walker
  16. #16 Re: Problems
    Jan 2013
    Michigan
    i can feel it through everything and it isn't when i just brake it does when im just going
  17. #17 Re: Problems
    because we can see it or hear it or feel it. your gonna have to jack the car up, and start testing parts out, push and pull tests, and so on.
    id think the hub went bad, jack the whell up, and grab the top of the tire, push and pull the wheel firmly, if it moves, the hub is bad.
  18. #18 Re: Problems
    Apr 2012
    Goderich, Ontario
    Could be a wheel bearing, cv shaft, breaks, bent or loose rim, unbalanced tire, ect. jack the front end up onto jack stands and look around. Are you fixing this yourself or just going to a shop? If so, let them figure it out, that's there job.
    -Paul Walker
  19. #19 Re: Problems
    Jan 2013
    Michigan
    i'm do alot of work this weekend on the car if i can find anything ill fix it if i have no clue ill take to a shop
  20. #20 Re: Problems
    Dokey okay, good sounds plan
  1. 04 GT1 Problems (again)
    By KirkpatrickJTK in forum General Tech Discussion
    Last Post: 10-23-2011, 06:32 PM
  2. HUD Problems
    By ms3206 in forum General Tech Discussion
    Last Post: 09-20-2011, 10:32 PM
  3. So many problems. . .
    By SDGTP99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2010, 02:09 PM
  4. A/C problems
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 11:04 PM
  5. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
