Thread: Trany line diagram
Results 1 to 11 of 11
  1. #1 Trany line diagram
    Aug 2013
    ny
    Is there diagrams for the trans lines to the radiator.
  2. #2 Re: Trany line diagram
    Dec 2012
    Where 4T65E's were born
    Don't think one is really needed, two lines go from the trans to the radiator, flowing from the bottom to the top of the cooler.
    Sold.
  3. #3 Re: Trany line diagram
    Aug 2013
    ny
    Yes cause im trying to take off the bottem line on my 98 gtp. Its leaking right at the nut! I dont remove the nut? Cause the nut is in the radiator itself right? I know like 2000 and newer gp have diff ways of connecting lines?
  4. #4 Re: Trany line diagram
    Dec 2012
    I'm not sure, I have a 2002 and I'm pretty sure the nut can unscrew. Is the plastic cracked or something? It's probably loose.
    Sold.
  5. #5 Re: Trany line diagram
    Aug 2013
    ny
    It's all rusted. I thought the nut comes with the rad like when yu get a new one. And the line just. Slips out when the clips out. I got the plastic clip out that was in front. Think I see another one. I hope there's a write up or so. Caus this leak was bad
  6. #6 Re: Trany line diagram
    i was just looking all this up myself due to a rad change, slide that plastic ring back then theres a clip thats holding the line into that nut.
    if need be that nut should come out. it did in the vid i watched on you tube.
  7. #7 Re: Trany line diagram
    Aug 2013
    ny
    It makes me wounder were the leak is I know it's at the nut but is there a o ring? The nut ain't movin for nothing. It's a 17 flare right
  8. #8 Re: Trany line diagram
    it may need a quick connect tool. ive yet to look at mine up close to see whats going on there.
  9. #9 Re: Trany line diagram
    Aug 2013
    ny
    Ty Scotty u been helpin a lot here. Wana know where the leak could be on it
  10. #10 Re: Trany line diagram
    Aug 2013
    ny
    You use a door panel remover tool that has that 90 deg point and take ring out.
  11. #11 Re: Trany line diagram
    Aug 2013
    ny
    What year they stop threaded?
  1. Found this in trany pan :(
    By Timing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2014, 03:15 PM
  2. vaccum line diagram 97 gtp
    By prettyboimike12 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2011, 08:59 PM
  3. engine trany won't seperate
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 12:23 PM
  4. trany holding up
    By ionroller in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2008, 01:41 PM
  5. Trany whines....I think
    By evlprx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2008, 01:14 PM
