Thread: tick in motor
Results 1 to 8 of 8
  1. #1 tick in motor
    SE Level Member lovebug's Avatar
    Mar 2013
    bemidji mn
    I have a Pontiac grand prix with a 3.1 v6 and when I start it theres a little tick in the motor but goes away when I let it run ive changed the oil .. what can it be and how can I fix it thanks
  2. #2 Re: tick in motor
    depending on miles it sounds like a lifter thats bleed pressure over night. you could try thicker oil next oil change. summers coming, 40 weights ok.
  3. #3 Re: tick in motor
    Mar 2013
    bemidji mn
    its a 1995 the miles are 168211 I just bought it about a month ago my first pontiac after I bypassed the a/c condenser because that was making alott of noise then I noticed this tick its not loud just noticeable. is it a big problem to worry about
  4. #4 Re: tick in motor
    if it goes away with in a few minutes when warming up the car, its fine. if it does it all day long id worry.
  5. #5 Re: tick in motor
    Mar 2013
    bemidji mn
    thank you, its only there when It first starts then goes away when it runs for a bit .... thanks again
    *lovebugg*
  6. #6 Re: tick in motor
    Donating Users mystic231's Avatar
    Michigan
    Drain a quart of oil out and add a quart of Marvel Mystery Oil; it's in a clear red bottle. Your sticky lifter will free up. I had the same issue on my '98 and it hasn't come back.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  7. #7 Re: tick in motor
    Mar 2013
    bemidji mn
    thank you so much its my first gp and already had 2 offers on it since ii got it last month it runs good and got it for a good price since theres some damage in the front driver side that is fixable ive been working on and the a/c condenser was a big issue so I bypassed that other than that things look good no rust anywhere I do need to order a spoiler and a few other things I need for it its just that annoying tick now .... ill give the mystery oil a try thank you again
    *lovebugg*
  8. #8 Re: tick in motor
    compressor is what you bypassed not the condenser.
  1. Engine Tick Help!
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2011, 09:46 PM
  2. Lifter tick?
    By My GTP 97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 01:03 PM
  3. Top end tick?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:42 AM
  4. Tick Tick Tick
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2009, 11:42 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
