Thread: 04 Prix Headlight Shaking/GM PART # 10388091
Results 1 to 4 of 4
  1. #1 04 Prix Headlight Shaking/GM PART # 10388091
    SE Level Member biggd1980's Avatar
    Feb 2013
    Iowa
    I see there is a bracket kit that can be purchased and installed to reduce/eliminate the headlights shaking on 2004 Grand Prix's. My question is if anyone knows the type and size of the bolt needed for the the black L bracket?? Seems the previous owner started to install the kit, but did not drill and put in that bolt on either headlight.
  2. #2 Re: 04 Prix Headlight Shaking/GM PART # 10388091
    The metal brackets itself should be enough to keep the headlights from bouncing. Personally I never brother installing the L bracket. No bounce here.
    04 Comp G.
  3. #3 Re: 04 Prix Headlight Shaking/GM PART # 10388091
    Nov 2012
    Madison
    I know when I bought the new metal brackets to replace the broke plastic clips I had to work them down pretty good. I had new headlight housings at the same time. I had to shave the bottom nipples on the backside of the lights so the clips would slide behind them. It would be easy to just push the clips down thinking they are secured and not have the bottom peg thru the clip. Mine are tight as all hell.
    Sorry I probably didn't answer your question.
  4. #4 Re: 04 Prix Headlight Shaking/GM PART # 10388091
    Sep 2013
    Minnesota
    Could someone pm me about the kit for 2004 grand prix headlight shaking or bouncing
  1. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 3
    By dsh1106 in forum How To Write-Ups/Tech Tips
    Last Post: 02-09-2013, 06:55 PM
  2. Replies: 7
    Last Post: 06-25-2012, 03:34 PM
  3. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 2
    Last Post: 04-17-2009, 02:20 PM
  4. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 1
    Last Post: 04-17-2009, 02:17 PM
  5. 02 Grand Prix GT Halo Headlights shaking....!
    By bjjnut in forum General Tech Discussion
    Last Post: 03-24-2009, 04:54 PM
